cannot get dwarf-2 file loaded
4 posts / 0 new
Hi I want to start using dwarf-2 instead of ext-coff but it seems to be an impossible task just to generate a file that can be loaded with Studio v4.10 B356.
First of all the code I'm using generated a perfectly fuctional EXTCOFF file which I could load into Studio and step with JTAG-MK2.
Since I used a makefile that has been cut and pasted so many times I thought I'd go back to a 'clean' file that is output by the Mfile v1.41 utility. So I specified all the options from the Mfile menu (including Debug Format = ELF/DWARF-2) but when I open the .elf file from Studio I get the message "Coordinator Error loading object file".
I studied the makefile and saw the line "ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs"
still contains the stabs option. So I changed it to
"ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),--gdwarf2". Still no joy with loading the .elf file in Studio.
Please, what can I do to generate a working DWARF-2 file?
Another Q about make:
Is there a way to cause make to automatically check if any of the #included files in a .c file changed and then recompile the .c file when a make all is done? At the moment this list of dependancies is specifies manually in my makefiles.
PS: I've attached my whole makefile and the output from the make process.
johannkok,
Have you picked up the latest patches for AVR Studio 4.10? If not, see my post of 19 Nov 2004 in this thread.
Don
Thanks donblake,
my problem was something unexpected - it turns out that Mfile's makefile was correct but I left my old Makefile in the same directory and just named Mfile's makefile "mfile". I then invoked it by the command "make mfile all" and as I eventually figured out this still calls the original Makefile too!
I suppose you all would say RYFM... and I did, but it's just too much information to remember it all at once when your new to the whole GCC toolchain.
regards
johannkok wrote:
Thanks donblake,
I can sympathize: it is a whole lot to learn. But you seem to be making good progress!
By default the make program looks for a makefile in the current directory with the name Makefile or makefile.
If you want to have make execute a makefile with a different name you can call it like this:
make -f
or like this:
make --file=
Where is the filename.
To get a quick list of available options, on the command line do this:
make --help
And there should be a section in the make user manual (comes with WinAVR) that gives a quick description of all the command line options. Luckily, in my practice, I've never really had to use hardly any of the command line options.
HTH
Eric
