programming Fast start fuse
2 posts / 0 new
Hi everyone,
Does anyone knows how to program the fast start fuse in an 8535 with the STK200 in circuit program?
thanks,
admin's test signature
Hi Yvon,
You simply open AVR ISP and your project, go to the "Security and fuses" tab in the project manager, and select the fuse to be programmed. Then you run a normal programming of your device. The new fuse setting will be available at next start-up. The status of the fuse bits is not affected by Chip Erase.
Best regards,
Morten, AVR tech. support, Atmel FAE
