[?] while-loop not exiting despite changes in conditon
9 posts / 0 new
Not sure why the while-loop didn't stop despite the condition changed in an interrupt function.
uchar counterByTheSec = 0;
sei();
TCNT1 = 0;
while(globalFlag==0x00){
  if(TCNT1>6000){
    counterByTheSec++;
    TCNT1 = 0;
  }else{
    if(counterByTheSec > 9) break;
cli();
The "globalFlag" is defined as extern uchar & its used in another file. The interrupt will be called & globalFlag will be set to 0x01 in less than 3 secs but the while-loop just continues despite the condition is already false & it just exit after 10 secs. I did a debugWire & did verified that the globalFlag was indeed 0x01 but the while-loop just go on & on. I am missing something :?
Once an engineer, forever an engineer
Oh yeah, I'm using AVR167 coding in AS6.
Yes, a "volatile".
Stefan Ernst
(sigh) I solved it after adding a delay_ms(1); but why?
I'm sorry, "volatile" ?
[TUT][C]Optimization and the importance of volatile in GCC
Stefan Ernst
Ah, got it now. Thanks a lot Stefan.
FAQ #1.
In short, if a variable is changed by more than one 'thread', it must be declared volatile. This prevents the compiler from performing certain optimisations concerning that variable.
Specifically, every time the variable is referenced in your code, the compiler is forced to access the variable (be it a read or a write).
Without volatile, the compiler might conclude that the variable never changes (in the current compilation unit), and optimise away some or all of the references.
Also, have a look at this.
JJ
"Read a lot.  Write a lot."
Thanks for the explanation & link (doc) JJ. Yeap, added to one of my "post-it" on the side of my screen....
