A little help with assembly please
10 posts / 0 new
I have almost zero avr assembly knowledge. I am trying to use a simple .s file which was for a different compiler, in GCC. The original was this:
_LoadZ::
  movw  Z, r16    ; Load R17:R16 into Z.
  ret
_LoadR0::
  movw  r0, r16   ; Load R17:R16 into R1:R0.
  ret
_ReadELPM::
  elpm r16, Z
  ret
I changed it to this:
.section .text
.global LoadZ
LoadZ:
  ret
.section .text
.global LoadR0
LoadR0:
  ret
.section .text
.global ReadELPM
ReadELPM:
  elpm r16, Z
  ret
and created this header file:
void LoadZ( unsigned int addr);
void LoadR0(unsigned int addr);
uint8_t _ReadELPM(uint8_t);
when I compile it throws an error that it was expecting a constant at
LoadZ:
I have tried a couple of changes but none worked. thanks
Why do you need the header file for?
Do you intend to combine C and asm?
JW
LoadZ:
  ret
try
LoadZ:
  movw  r30, r16    ; Load R17:R16 into Z.
  ret
instead.
And if you intend to combine asm and C you need to follow the ABI.
Yes I do. So would that mean it would have to change to?:
LoadZ:
  movw  r30, r24    ; Load R25:R24 into Z.
  ret
The easiest way to figure out how to follow the ABI is to start with writing your function in C, with the C function header header looking the way you want. Compile and see what assembler code the compiler emits.
Now write your assembler-implementation doing the interface the same way.
LoadZ:
  ret
Yes that's better. But you can not know if the value in Z is still there if you later call ReadELPM.
Add -save-temps and -fverbose-asm to your compiler options and each file.c will create a file.s in the build directory. What I suspect you will find is that 90% of the time the C compiler does as well as you could so there's very little point in implementing code in .s files unless it's truly uber time critical and you really need to shave a few cycles.
If you want the .s files to be even better the search for "avr-source" at http://spaces.atmel.com
I have been trying to get a bootloader to work on an xmega64a3u for about the last week. Those that have no source files work. Those that have source files dont. I did try xboot but did not manage to get it to make using windows. I eventually gave up :https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=137615
I have also being trying to get the one from bandtank to work: https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=137490
I read on this link https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&p=1111789#1111789 that he had a similar problem so he decided to re-write the sp_driver in C. But he does not use GCC and he does have some assembly stuff in it. I thought I would give it a try on my chip, and then if it works try figure out why the code I have does not.
That bit of assembly is used like this:
    // Load multiple bytes into page buffer
    for (i = 0; i < (FLASH_PAGE_SIZE * 2); i+=2)
        LoadR0(*int_ptr);
        LoadZ(i);
        CPU.CCP = CCP_SPM_gc;
        asm("spm");
        int_ptr++;
So to solve my problem I either have to get somebody who has source for a bootloader in a x64a3u to tell me how they got it to work, or I need to try this code out to see if it works. Any suggestions?
#include
for(i=0; i< 2*FLASH_PAGE_SIZE; i+=2, ++int_ptr) {
    boot_page_fill_safe(*int_ptr, *int_ptr);
} // i
Edit: don't know about CPU. .
"SCSI is NOT magic. There are *fundamental technical
reasons* why it is necessary to sacrifice a young
goat to your SCSI chain now and then." -- John Woods
In another thread I told you that boot.h contains about 90% of what you need to create a bootloader. I think you'll find that boot_program_page() (or whatever it's called) is as asm macro doing almost exactly the same as that sequence you showed. Start here
