Any gotchas using --relax
8 posts / 0 new
I am hoping that someone might be able to provide some insight in to problems I am encountering using the --relax linker directive
I have a project in my care that for historic reasons uses the 20070122 toolset to compile for the Atmega2560
I need to make space in this project to add a couple of new features and hoped to make use of the 3kB (approx) that I can see following trampolines
Unfortunately if I use the -Wl,--relax directive the code does not seem to link correctly:
- the space behind the trampolines is used as I would expect
- but the code does not work: function calls go awry and I am finding it difficult to see any pattern as to where or why
This makes it pretty difficult to debug what to try next: so I'm hopping there might be some suggestions here?
If I use WinAVR-20100110 (the most recent tool chain I have to hand) the code will link correctly IFF I use the --relax directive (otherwise it runs out of space)
- however with this version of the tool chain I find that the code generated is bigger than in the 20070122 case without the --relax directive
- hence I am returned to square one needing to find space to add the bits I require
Being able to recover the space I can see via --relax on the 20070122 would be the quickest win I could get here
Thanks in advance for any suggestions that might be offered
(I will investigate what happens under the recent version 3.4.1 of the toolchain)
All the best,
sd
Then try Atmel's Toolchain 3.4.2 which contains compiler 4.7.2.
- I'm currently working through the changes I need to do to see if Toolchain 3.4.2 gives any gains (renaming ISR vectors & repositioning "const" keywords mostly)
- I'll keep my fingers crossed
sd
Isn't it the same as
any
const char[]
in ram?
No RSTDISBL, no fun!
WinAVR20100110 contains avr-gcc 4.3.3
The Atmel version contains 4.7.2 which has lots of "goodies" like __flash and is considerably "newer" by about 3 years. There are bug fixes, new features and in my experience the code generation is better.
Oops, I have just noticed that I have WinAVR2010010 on hdd but my avr-gcc is 4.7.2 and from there I can see I had to upgrade avr-gcc in the meantime but I have no idea when :?:
I've spend the best part of the day getting the code to play nicely with the 4.7.2. compiler
- and I find that I am encountering pretty similar behaviour (but at least on a compiler from the correct decade!)
There is around 98% of the Chip flash used if I do not issue --relax and 94.8 if I do
- but the "relaxed" code fails; whereas the code works nicely without
So it is apparent that the linker is doing something based on the --relax but ending up with code that does not run correctly
- is it likely I have failed to specify something somewhere else which is causing this?
- the compiler options are:
avr-gcc -Os -Wundef -Wall -gdwarf-2 -mcall-prologues -fno-strict-aliasing -frename-registers -DCOMPILER_GCC -mmcu=atmega2560 -std=gnu99 -DARCH_AVR
- and those for the linker:
avr-gcc -mmcu=atmega2560 -gdwarf-2 -Wl,-T,C:\{buildpath}avr8_local.x -Wl,--relax -Wl,-defsym=__heap_end=0x80ffff,-Map,linker.map
The linker scrip is there to configure external memory & looks like:
/* based on default linker script, for normal executables, but with external memory definitions*/
__xram_start_address = 0x2200 ;
OUTPUT_FORMAT("elf32-avr","elf32-avr","elf32-avr")
OUTPUT_ARCH(avr:6)
MEMORY
  text   (rx)   : ORIGIN = 0, LENGTH = 1024K
  data   (rw!x) : ORIGIN = 0x800200, LENGTH = 0xfe00
  eeprom (rw!x) : ORIGIN = 0x810000, LENGTH = 64K
  fuse      (rw!x) : ORIGIN = 0x820000, LENGTH = 1K
  lock      (rw!x) : ORIGIN = 0x830000, LENGTH = 1K
  signature (rw!x) : ORIGIN = 0x840000, LENGTH = 1K
  user_signatures (rw!x) : ORIGIN = 0x850000, LENGTH = 1K
SECTIONS
  /* Read-only sections, merged into text segment: */
  .hash          : { *(.hash)		}
  .dynsym        : { *(.dynsym)		}
  .dynstr        : { *(.dynstr)		}
  .gnu.version   : { *(.gnu.version)	}
  .gnu.version_d   : { *(.gnu.version_d)	}
  .gnu.version_r   : { *(.gnu.version_r)	}
  .rel.init      : { *(.rel.init)		}
  .rela.init     : { *(.rela.init)	}
  .rel.text      :
      *(.rel.text)
      *(.rel.text.*)
      *(.rel.gnu.linkonce.t*)
  .rela.text     :
      *(.rela.text)
      *(.rela.text.*)
      *(.rela.gnu.linkonce.t*)
  .rel.fini      : { *(.rel.fini)		}
  .rela.fini     : { *(.rela.fini)	}
  .rel.rodata    :
      *(.rel.rodata)
      *(.rel.rodata.*)
      *(.rel.gnu.linkonce.r*)
  .rela.rodata   :
      *(.rela.rodata)
      *(.rela.rodata.*)
      *(.rela.gnu.linkonce.r*)
  .rel.data      :
      *(.rel.data)
      *(.rel.data.*)
      *(.rel.gnu.linkonce.d*)
  .rela.data     :
      *(.rela.data)
      *(.rela.data.*)
      *(.rela.gnu.linkonce.d*)
  .rel.ctors     : { *(.rel.ctors)	}
  .rela.ctors    : { *(.rela.ctors)	}
  .rel.dtors     : { *(.rel.dtors)	}
  .rela.dtors    : { *(.rela.dtors)	}
  .rel.got       : { *(.rel.got)		}
  .rela.got      : { *(.rela.got)		}
  .rel.bss       : { *(.rel.bss)		}
  .rela.bss      : { *(.rela.bss)		}
  .rel.plt       : { *(.rel.plt)		}
  .rela.plt      : { *(.rela.plt)		}
  /* Internal text space or external memory.  */
  .text :
    *(.vectors)
    KEEP(*(.vectors))
    /* For data that needs to reside in the lower 64k of progmem.  */
    *(.progmem.gcc*)
    *(.progmem*)
    . = ALIGN(2);
     __trampolines_start = . ;
    /* The jump trampolines for the 16-bit limited relocs will reside here.  */
    *(.trampolines)
    *(.trampolines*)
     __trampolines_end = . ;
    /* For future tablejump instruction arrays for 3 byte pc devices.
       We don't relax jump/call instructions within these sections.  */
    *(.jumptables)
    *(.jumptables*)
    /* For code that needs to reside in the lower 128k progmem.  */
    *(.lowtext)
    *(.lowtext*)
     __ctors_start = . ;
     *(.ctors)
     __ctors_end = . ;
     __dtors_start = . ;
     *(.dtors)
     __dtors_end = . ;
    KEEP(SORT(*)(.ctors))
    KEEP(SORT(*)(.dtors))
    /* From this point on, we don't bother about wether the insns are
       below or above the 16 bits boundary.  */
    *(.init0)  /* Start here after reset.  */
    KEEP (*(.init0))
    *(.init1)
    KEEP (*(.init1))
    *(.init2)  /* Clear __zero_reg__, set up stack pointer.  */
    KEEP (*(.init2))
    *(.init3)
    KEEP (*(.init3))
    *(.init4)  /* Initialize data and BSS.  */
    KEEP (*(.init4))
    *(.init5)
    KEEP (*(.init5))
    *(.init6)  /* C++ constructors.  */
    KEEP (*(.init6))
    *(.init7)
    KEEP (*(.init7))
    *(.init8)
    KEEP (*(.init8))
    *(.init9)  /* Call main().  */
    KEEP (*(.init9))
    *(.text)
    . = ALIGN(2);
    *(.text.*)
    . = ALIGN(2);
    *(.fini9)  /* _exit() starts here.  */
    KEEP (*(.fini9))
    *(.fini8)
    KEEP (*(.fini8))
    *(.fini7)
    KEEP (*(.fini7))
    *(.fini6)  /* C++ destructors.  */
    KEEP (*(.fini6))
    *(.fini5)
    KEEP (*(.fini5))
    *(.fini4)
    KEEP (*(.fini4))
    *(.fini3)
    KEEP (*(.fini3))
    *(.fini2)
    KEEP (*(.fini2))
    *(.fini1)
    KEEP (*(.fini1))
    *(.fini0)  /* Infinite loop after program termination.  */
    KEEP (*(.fini0))
     _etext = . ;
  }  > text
  .data	  : AT (ADDR (.text) + SIZEOF (.text))
     PROVIDE (__data_start = .) ;
    /* --gc-sections will delete empty .data. This leads to wrong start
       addresses for subsequent sections because -Tdata= from the command
       line will have no effect, see PR13697.  Thus, keep .data  */
    KEEP (*(.data))
    *(.data*)
    *(.rodata)  /* We need to include .rodata here if gcc is used */
    *(.rodata*) /* with -fdata-sections.  */
    *(.gnu.linkonce.d*)
    . = ALIGN(2);
     _edata = . ;
     PROVIDE (__data_end = .) ;
  }  > data
   __data_load_start = LOADADDR(.data);
   __data_load_end = __data_load_start + SIZEOF(.data);
  .bss  SIZEOF(.data) + ADDR(.data) :
     PROVIDE (__bss_start = .) ;
    *(.bss)
    *(COMMON)
     PROVIDE (__bss_end = .) ;
  }  > data
  /* reset info structure -- not cleared at reset  */
  .resinfox  (0x800000 + __xram_start_address) :
	AT (0x800000 + __xram_start_address)
     PROVIDE (__resinfox_start = .) ;
    *(.resinfox*)
     PROVIDE (__resinfox_end = .) ;
  }  > data
  /* power device info -- not cleared at reset */
  .powerx   SIZEOF(.resinfox) + ADDR(.resinfox) :
     PROVIDE (__powerx_start = .) ;
    *(.powerx*)
     PROVIDE (__powerx_end = .) ;
  }  > data
  /* external RAM -- cleared at reset  */
  .bssx  SIZEOF(.powerx) + ADDR(.powerx) :
     PROVIDE (__bssx_start = .) ;
    *(.bssx)
     PROVIDE (__bssx_end = .) ;
  }  > data
  /* Global external data not cleared at reset  */
  .noinitx  SIZEOF(.bssx) + ADDR(.bssx) :
    PROVIDE (__noinitx_start = .) ;
    *(.noinitx)
     PROVIDE (__noinitx_end = .) ;
     _endx = . ;
     PROVIDE (__heap_start = .) ;
     PROVIDE (__heap_end = 0x80ffff) ;
   } > data
  /* Global data not cleared after reset.  */
  .noinit  SIZEOF(.bss) + ADDR(.bss) :
     PROVIDE (__noinit_start = .) ;
    *(.noinit*)
     PROVIDE (__noinit_end = .) ;
     _end = . ;
  }  > data
  .eeprom  :
    KEEP (*(.eeprom*))
     __eeprom_end = . ;
  }  > eeprom
  .fuse  :
    KEEP(*(.fuse))
    KEEP(*(.lfuse))
    KEEP(*(.hfuse))
    KEEP(*(.efuse))
  }  > fuse
  .lock  :
    KEEP(*(.lock*))
  }  > lock
  .signature  :
    KEEP(*(.signature*))
  }  > signature
  .user_signatures  :
    KEEP(*(.user_signatures*))
  }  > user_signatures
  /* Stabs debugging sections.  */
  .stab 0 : { *(.stab) }
  .stabstr 0 : { *(.stabstr) }
  .stab.excl 0 : { *(.stab.excl) }
  .stab.exclstr 0 : { *(.stab.exclstr) }
  .stab.index 0 : { *(.stab.index) }
  .stab.indexstr 0 : { *(.stab.indexstr) }
  .comment 0 : { *(.comment) }
  /* DWARF debug sections.
     Symbols in the DWARF debugging sections are relative to the beginning
     of the section so we begin them at 0.  */
  /* DWARF 1 */
  .debug          0 : { *(.debug) }
  .line           0 : { *(.line) }
  /* GNU DWARF 1 extensions */
  .debug_srcinfo  0 : { *(.debug_srcinfo) }
  .debug_sfnames  0 : { *(.debug_sfnames) }
  /* DWARF 1.1 and DWARF 2 */
  .debug_aranges  0 : { *(.debug_aranges) }
  .debug_pubnames 0 : { *(.debug_pubnames) }
  /* DWARF 2 */
  .debug_info     0 : { *(.debug_info) *(.gnu.linkonce.wi.*) }
  .debug_abbrev   0 : { *(.debug_abbrev) }
  .debug_line     0 : { *(.debug_line) }
  .debug_frame    0 : { *(.debug_frame) }
  .debug_str      0 : { *(.debug_str) }
  .debug_loc      0 : { *(.debug_loc) }
  .debug_macinfo  0 : { *(.debug_macinfo) }
  /* DWARF 3 */
  .debug_pubtypes 0 : { *(.debug_pubtypes) }
  .debug_ranges   0 : { *(.debug_ranges) }
  /* DWARF Extension.  */
  .debug_macro    0 : { *(.debug_macro) }
- if there are no quick wins wrt this directive I guess I'll start looking at what I can do to prune the code given the new tools in this version of the compiler
does using __flash result in the same code as using PROGMEM and its associated routines?
- I'll pick a small data table and see what happens
All the best,
sd
Does the whole .trampolines section in your application fit under the 64kW limit?
JW
