Flipping the port
8 posts / 0 new
I have a parallel DAC that is hooked up to my mega32's PORTC. The problem I am having is that the MSB of the DAC is connected(via PCB) to PC0 the next MSB is connected to PC1 and so on. So I need to "flip the port" to output the correct value. Here is an example: after a conversion of the internal ADC the result is stored in a general purpose register. If the result is 0101 1001 I need to flip this number to 1001 1010 and output it on PORTC. any suggestions :?: would be helpful.
why cant you just connect the data lines correctly instead of backwards? and is this in C or assembly?
in assembly the easiest way to do it would probably be to do 8 ROR/ROL instructions.
ROR data
ROL flippedData
ROR data
ROL flippedData
ROR data
ROR data
ROL flippedData
ROR data
ROL flippedData
or use a simple loop
/* John Butera */
This has been discussed on the Forum in gory detail in the past. The straightforward solution is shown by Pepsi. You can also follow-up on
http://2313.avrfreaks.net/phpBB2...
leading you to
Lee
works great :D . I simulated it in AVR Studio 4 with a few test variables and it seems to do what I want. But how does it work? Does it shift the carry bit into the fliped data register?
Yes
Keep it simple it will not bite as hard
Yes
Lets make this a negative comment free zone!
No.
John_A_Brown wrote:
Yes
No.
Maybe
The unrolled loop of eight sets of
        ROR     data
        ROL     flippedData
requires 16 words of instruction memory and 16 clock cycles to execute.
The minimum loop
        ldi	flippedData,low (0xFE)
loop:
        ror        data
        rol        flippedData
        brcs  loop
requires 4words of instruction memory and 32 clock cycles to execute.
An example of the usual size/time tradeoff.
