Keypad works only in active low
3 posts / 0 new
Hello, i am sure i am doing something wrong here and its most probably my coding. I have a ATmega164P and i am interfacing a 4x4 keypad with it. I know the working of keypad so here is the code which set a state to row1 and scans the columns
void r1(void)
	DDRC = 0xF0;
	PORTC=0x7F;
	_delay_ms(200);
	if ((PINC & (1<<PC3)) == 0)
		LCDdata('1');
		_delay_ms(200);
	else if ((PINC & (1<<PC2)) == 0)
		LCDdata('2');
		_delay_ms(200);
	else if ((PINC & (1<<PC1)) == 0)
		LCDdata('3');
		_delay_ms(200);
	else if ((PINC & (1<<PC0)) == 0)
		LCDdata('A');
		_delay_ms(200);
The rows are connected to higher nibble of PORTC and Columns are connected to lower nibble.
Now in this code i am setting the MSB to Low, and then checking the lower nibble for low state.
My questions is: When i check the PIN register for a high state, the code does not work e.g:
	DDRC=0xF0;
	PORTC=0x80;
	if ((PINC & (1<<PC3)) == 1) //checking for a high
		LCDdata('1');
		_delay_ms(200);
For some reason this does not work... i want to know why?
a side question: as you can see the pin7 is state low, and when a key is pressed, it shorts a high pin with a low pin(i.e PIN1 with PIN7) i hope this is not a problem?
Because if for example bit 4 is on, the value is not 1 but 16. You might want to compare if it is just not zero.
No (but read below), because high nybble is output and low nybble is input. But if you have no pull-up resistors, floating inputs have no defined state and could read as one or zero. This is why the first one is better, it enables pull-ups on inputs, and all input pins are high if no button is pushed, and a pushed button reads low.
You do have a problem if you push more than one button, as it can short-circuit two outputs if you have no diodes in your circuit. Perhaps it would be best to use only open-collector output mode to pull low one row bit and leave other row bits as (pulled-up) inputs.
There are tons of code already on the web, e.g.:
Peter
