ATtiny45 Using Fleury's I2c issues
4 posts / 0 new
Hey guys, this is my first post so take it east on me. I am trying to use Fleury's I2c library with Atmel Studio 6.2. I am having issues reading an ADC value from a PCF8591 and figured I would see what you guys thought. I am new to I2c communication so any information would help. My code is very basic and all I am doing is setting a DAC value, taking an A/D read then comparing that A/D value with a limit to turn an LED on or Off. Here is my code:
#include
#include "i2cmaster.h"
#include
#define PCF8591_0 0x90      // Device address = 000
#define DAC 0x40			// DAC ID = 0x40
#define ADC0 0x40			// ADC0 ID = 0x40
#define ADC1 0x41			// ADC1 ID = 0x41
#define ADC2 0x42			// ADC2 ID = 0x42
#define ADC3 0x43			// ADC3 ID = 0x43
	DDRB |= (1<<DDB1);  //Pin 6 as Output
	uint8_t AtoD_Read;
	uint8_t Dac_Value;
	i2c_init();
	Dac_Value=0xff;
		_delay_ms(5);
		SetDac(PCF8591_0,DAC,Dac_Value);
		AtoD_Read = AdcRead(PCF8591_0,ADC0);
		if(AtoD_Read > 0x7F)
			PORTB &= ~(1<<PORTB1);
			PORTB |= (1<<PORTB1);
		Dac_Value--;
		if(Dac_Value < 0)
			Dac_Value = 0xff;
And here are my functions:
void SetDac(uint16_t DevID, uint16_t DacID,uint16_t DacValue)
	i2c_start_wait(DevID+I2C_WRITE);					//Device ID
	i2c_write(DacID);					//Enable DAC
	i2c_write(DacValue);				//Set DAC to ~1.0v
	i2c_stop();							//Stop I2C Transmission
uint8_t AdcRead(uint16_t ADC_DevID, uint16_t Channel)
	uint8_t	ret;
	i2c_start_wait(ADC_DevID+I2C_WRITE);     // set device address and write mode
	i2c_write(Channel);
	i2c_rep_start(ADC_DevID+I2C_READ);       // set device address and read mode
	i2c_readAck();
	ret = i2c_readNak();
	i2c_stop();
	return(ret);
So with this code what I am seeing is the SetDac(); function works perfectly however when I take an A/D read I get bogus data. My LED on PB1 just blinks randomly and not around my limit or ~.7v. I am using 1.5v for my reference voltage on the PCF8591 and it is addressed to zero (A0 = 0, A1 = 0, and A2 = 0).
Any idea what I might be doing wrong?[/code]
I have not looked at your data sheet. However, if it wants 16-bit data, I should use 16-bit e.g.
   i2c_write(DacValue>>8);         //hi
   i2c_write(DacValue);            //lo
uint16_t AdcRead(uint16_t ADC_DevID, uint16_t Channel)
   uint16_t   ret;
   i2c_write(Channel);
   ret = i2c_readAck() << 8;        // hi
   ret |= i2c_readNak();            // lo
   i2c_stop();
   return(ret);
You may only want 8-bits. However, re-usable functions are always useful. Simply throw away any unwanted bits.
I cant believe that your chip has a 16-bit channel numbers. If it does, you would write two 8-bit bytes for Channel.
Atmel Studio 6.2.
Do you mean AS6.1 SP2 or do you have some new secret version?
Good eye, I forgot to change that back to "uint8_t".
SP2
