Direc access to sram address
12 posts / 0 new
How to read / write to specific address on sram ?
I used this code but i think there is better choice to do this:
#define BASE_PARAM 0x1f80
volatile uint8_t* pPARAM = (uint8_t*) BASE_PARAM; //puntatore PARAMETRI alla ram
void ram_par_write_byte(uint8_t addr,uint8_t dato){
			pPARAM=(uint8_t *)(BASE_PARAM+addr); 				//imposta puntatore
			*pPARAM = dato;
void ram_par_write_int(uint8_t addr,uint16_t dato){
			uint16_t temp;
			uint8_t div,resto;
			temp = dato;
			div = temp / 256;
			*(pPARAM+1) = div;
			resto = (temp - (div * 256));
			*(pPARAM+0) = resto;
uint8_t ram_par_read_byte(uint8_t addr){
			uint8_t dato;
			return dato=*pPARAM; 					 //read ram byte
uint16_t ram_par_read_int(uint8_t addr){
			uint16_t dato;
			return dato=*pPARAM + (*(pPARAM+1)*256); //read ram int
That seems fine but I don't wholly understand why your int write function is so complicated? Surely you just cast the address to be an int pointer then write through it? No point in using a pointer to 8 bits then having to split the int.
unfortunately I do not know how you do, please can you show me?
I found an error with.....
uint32_t ram_par_read_dword(uint8_t addr)
void ram_par_write_dword(uint8_t addr,uint32_t dato)
and help would not hurt
i made some variation but the error remain
i don't know if in write o read function
highest byte[3] e higher byte[2] are always 0xFF , the lower byte[0] and high[1] are correct!
void ram_par_write_dword(uint8_t addr,uint32_t dato){
			*(pPARAM+3) = (dato >> 24) & 0xFF;
			*(pPARAM+2) = (dato >> 16) & 0xFF;
			*(pPARAM+1) = (dato >> 8) & 0xFF;
			*(pPARAM+0) = (dato >> 0) & 0xFF;
uint32_t ram_par_read_dword(uint8_t addr){
			uint32_t dato; dato=0;
			return dato = (*(pPARAM+3)<<24) | (*(pPARAM+2)<<16) | (*(pPARAM+1)<<8) | *pPARAM  ; //read ram dword
void ram_par_write_dword (uint8_t addr, uint32_t dato) {
    *(uint32_t*)(BASE_PARAM+addr) = dato;
uint32_t ram_par_read_dword (uint8_t addr) {
    return *(uint32_t*)(BASE_PARAM+addr);
Stefan Ernst
BTW what's the point of absolute addressing anyway? Presumably there are two things "seeing" the same locations - why can't they both just access it symbolically?
If that is the case, is not "union" a common solution?
#define lvalat(addr, tipe)   (*(tipe *)(addr))
Why?
sternst everything works perfectly, thank you all, I have to study more
clawson, I have a copy in ram of a set of EEROM parameters that need to be close
a long time since I was in avr freaks, there must come back more often ..
there is a nice atmosphere here :)
Why don't you just group all the parameters in a struct and block read/write it?
Indeed. And why does the SRAM copy need to be at a hard address? And even if that is desired, why not use the linker to place the variables and then use symbolic access?
