Months ago named address spaces have been introduced into gcc. And there was __pgmx address space, which uses 24-bit pointers. What happened with that? Now __pgmx is not recognized by compiler (avr-gcc 4.7.2 from Atmel Toolchain), __flashx too. __memx works fine. How I can use a linear 24-bit address pointer which points into FLASH?
What happened to __pgmx address space?
__pgm was renamed to __flash.
__pgmx was renamed to __memx.
AFAIK none of the "old" names made it into a GCC release.
Ok, but __memx is a generic address space for SRAM and FLASH. How can I get a 24-bit pointer which points only into FLASH for devices with >64 kB of FLASH?
And btw, can you take a look into the following topic:
There is no 24-bit, flash-only address space.
"initializer element is not computable at load time" means that the address spaces don't match. You need something like PGMX_STR that yields a __memx pointer.
BTW, I’ve found a piossible bug in __memx implementation. Take a look at the following example:
#includeextern __memx const uint8_t _binary____intro8kHz8PWMHL_raw_end; extern __memx const uint8_t _binary____intro8kHz8PWMHL_raw_size; extern __memx const uint8_t _binary____intro8kHz8PWMHL_raw_start; extern __memx const uint8_t _binary____intro16kHz16PCM_raw_start; extern __memx const uint8_t _binary____intro16kHz16PCM_raw_size; extern __memx const uint8_t _binary____intro16kHz16PCM_raw_end; uint8_t bufor[10]; int main(void) { __memx const uint8_t *ptr; uint32_t start1=(__uint24) &_binary____intro8kHz8PWMHL_raw_start; ptr=&_binary____intro8kHz8PWMHL_raw_start; for(uint8_t i=0; i<10; i++) bufor[i]=*ptr++; while(1) { //TODO:: Please write your application code } }
It won’t compile with the following error (gcc 4.7.2):
Error 2 in convert_debug_memory_address, at cfgexpand.c:2491 bin\bindata\bindata\bindata.c 40 5 bindata
If I will use your gcc 4.8.0, it crashes:
bin\bindata\bindata\bindata.c(43,11): unused variable 'start1' [-Wunused-variable]
bin\bindata\bindata\bindata.c(40,5): in convert_debug_memory_address, at cfgexpand.c:2527
bin\bindata\bindata\bindata.c(40,5): Segmentation fault
The symbols _binary____intro8kHz8PWMHL* and _binary____intro16kHz16PCM* are external symbols to obj files with raw data.
This is known as PR52472, see gcc(dot)gnu(dot)org/PR52472
As a work around you can compile without debug info.
Thanks.
