prefered method of checking digital input pins
13 posts / 0 new
Is there a preferred method to check and process Digital input pins?
I have to check 4 pins, 3 on PORTE one on PORTD. All pins start at high and I scan for a low. the pins are connected to switches rather than button and I know I still have to de-bounce.
if ((PINE & 0x10)==0)  //switch 1
		// do something
	if ((PINE & 0x20)==0)  //switch 2
		// do something
	if ((PINE & 0x40)==0)  //switch 3
		// do something
at present I check each pin individually but presume there is a better/faster method.
So far I have managed but wonder if there is a preferred way to check the port pins for changes?
Nigel
Nigel
If each pin must initiate a separate action (i.e. different "// do something"s), then what you have is fine. Although, the compiler may or may not handle your tests optimally. I also would suggest avoiding magic numbers. Use the device macros. I might suggest:
if (!(PINE & (1<<PE4)))  //switch 1
  // do something
if (!(PINE & (1<<PE5)))  //switch 2
  // do something
if (!(PINE & (1<<PE6)))  //switch 3
  // do something
Although frankly, I would expect the compiler to generate the same code for both.
If you simply need to know that any pin has gone low:
if ((PINE & ((1<<PE6)|(1<<PE5)|(1<<PE4))) != ((1<<PE6)|(1<<PE5)|(1<<PE4))){
  // do something
This has the advantage of sampling all pins at the exact same instant. With only three pins, it may not be faster than checking each pin in sequence, but it might be faster if in the case of more pins.
Compile several examples and compare the assembled output.
JJ
I would not combine the reading of the switches and the processing of the switches, the way you have. I would have a read_switches function, followed by a process_switches function. Encode the switches as individual bits in an unsigned value (8,16 or 32 bits, depending on how many switches). Once encoded that way, you can check for individual switches with a 1-bit mask, or 1-of-N switches or keys with an N-bit mask
For switches it probably doesn't matter but sometimes you need to take an instantaneous snapshot of all inputs so don't use:
  // do something
  // do something
  // do something
but something like:
uint8_t buttons = !PINE;
if (buttons & (1<<PE4))  //switch 1
  // do something
if (buttons & (1<<PE5))  //switch 2
  // do something
if (buttons & (1<<PE6))  //switch 3
  // do something
This also has the advantage that the volatile source (PINE) is only read once so the compiler doesn't have to generate three sets of identical code to read it (as volatile requires) so the code is shorter/faster/more efficient. You also get to do the ! inversion once at the top and the following logic is easier to read as the tests are positive not negative.
But that's either 0 or 1. You mean
uint8_t buttons =  ~PINE;
if (stripped(door) == PINE)
  repaint(door);
There's something you don't see very often. Cliff with pants down... :D
Only one coffee so far this morning - clearly more caffeine needed here :oops:
  repaint(door);
if (PINE == for_the_fjords) {
  cli();
  wdt_enable(WDTO_15MS);
  while(1) {}
Ut oh. A limerick may be just around the corner.
I typically "gather" my inputs/buttons/switches from the various ports and pins and enter into the parallel debounce rountine. See "key_fetch" in this link, and related/supporting in other forum search results for "key_fetch".
  // do something
  // do something
  // do something
To me, PE4 is as magic as 4.
I would use my macros for handling port bits by name, e.g.
"if(pval(LIGHT_SWITCH)) { ... }" or "if(pval(MOTOR_SWITCH)) { ... }".
Their uses would be preceded by definitions like
#define LIGHT_SWITCH_LET E
#define LIGHT_SWITCH_BIT 4
#define MOTOR_SWITCH_LET E
#define MOTOR_SWITCH_BIT 6
The definition of pval is left as an exercise for the reader.
As this involves debouncing,
I might instead have subsystems that debounce the switches attached to ports E and D.
The parameters distinguishing the subsystems would be a port letter and a mask.
I'd use macros to give the switches names,
but the subsystems would not know them.
"Demons after money.
Whatever happened to the still beating heart of a virgin?
No one has any standards anymore." -- Giles
Wow thanks guys, You know I now have to go read loads more... im not sure I have sufficient room left in my noggin!
I think I may have to use a mix and match of methods from above. using good names within some defines looks good. I have just started to use them!
regards
Nigel
