attiny24/A PWM problem [solved: write wrong register]
3 posts / 0 new
Hi guys
I was trying to program an attiny24 to generate a 50Hz PWM signal on pin 8(PA5/OC1B), but I got nothing, could someone have a look at my codes please, thanks a lot!
Here is my code:
#define F_CPU 1000000UL
#include
#include
	OCR1A = 20000;		//set top count for timer1
	TCCR0A |= (1<<COM1B1);			//clear OC1B on match, set on bottom
	/* set timer1 to Fast PWM mode, top value = OCR1A */
	TCCR0A |= (1<<WGM10) | (1<<WGM11);
	TCCR0B |= (1<<WGM12) | (1<<WGM13);
	TCCR0B |= (1<<CS10);			//no pre-scaler
	OCR1B = 1000;
	DDRA |= (1<<PA5);
Zhuhua Wu - Electronic Engineering Student
You are setting the OCR registers for timer 1, but the other registers for timer 0.
Steve A.
me, I did this again, I actually stuck on this for over half hour.
Thanks Steve
