Compilation problems Zigbit Bitcloud 1.14.0 with AS6.1
2 posts / 0 new
I attempted to compile the WSNDemo project available in the Bitcloud package.
Apart some missing "const" in the declaration of memprog variables, the compilation is correctly completed.
The problem is that the HEX file is much smaller than those pre-compiled available in the package - and of course does not work.
So I wonder if there is something to adjust in the makefile.
Another question is about fuses. The quick start guide says to enable the division by 8 of the clock, so the MCU should run at 1 MHz. This seems absurd to me, but maybe I really have to do so.
Any hint, apart from returning to Xbee modules? :twisted:
1. You need to change the linker script: https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&p=1044979#1044979
2. BitCloud will switch clock to 8MHz after calibration.
