com programming
4 posts / 0 new
Im trying to make a vb based program to control avr studio 4. Could somebody provide me with the descriptions of all the available objects, methods, classes, etc?
Thanks!
Go ask Atmel.
Hallo friend. If you are trying to build an emulator circuit just forget about this. I tried in the past to make what you want to do now.
DDE Method (VB 6 Dynamic Data Exchange) does not work with AVR Studio. No other way to comunicate with AVR Studio using a high level Language (or low level offcourse).
Remember that using DDE Method you can read ssssssssss............. Microchip's MPLAB data. But only to read from MPLAB, not to write.
So, no way to do this work.
Michael Karaoglanidis
Michael.
User of:
IAR Embedded Workbench C/C++ Compiler
Altium Designer
Hi Mark,
I think that the sollution for on your problem is to make a VB project for reading serial files.
The most simple method to do this is to use the command "Open" to open the file you want to read.
You have to be carerfull because you must have the same advice format in all your files (only those you wanna read from the VB project.
For any other help you can read the MSDN library.
Remember my friend that there is no way to comunicate with the AVRStudio. Unfortunately not.
Michael.
Michael.
User of:
Altium Designer
