1-Wire library, is there one? if multiple, which one choose?
12 posts / 0 new
Hi there,
I need to access Maxim/Dallas 18B20 thermometers, using 1-wire protocol.
Is there a (good) library for 1-wire protocol, for avr-gcc?
[I don't want to program in Bascom]
For LCD I am using Peter Fleury's lib,
for I2C (hardware), routines Joerg included in avr-libc examples.
If I remember correctly Atmel posted a flexible 1 wire lib, but it was for the IAR compiler.
Shouldn't be too hard to convert to GCC though.
Have a look here
http://www.siwawi.arubi.uni-kl.d...
/Bingo
https://code.google.com/p/atmega-clib/
https://code.google.com/p/atmega-clib/source/browse/branches
You can import them as Eclipse projects. It works with the most recent Atmel Toolchain
If you work with Atmel Studio, you can import the Solution from here:
https://code.google.com/p/atmel-clib/
@Bingo600: looks good (first impression looking into code).
As I have to respect strict timing (synced to line), *and* measure temperature, I started to think about adding an Tiny in 8pin, and connect it to main (now Mega8) using SPI... To be able to use only short (SPI / 2-3bytes) transfer with interrupts disabled...
@funlw65: Yours is far too big for me, and it looks i is the same (1W part), the Bingo600 pointed me at.
I am having problems using this lib:
- device seems to respond (at least if I "manually" issue "1W reset" condition - I measure "presence" pulse), but
- when I try (simplest possible code for an 1wire device):
"ow_reset"
"byte_wr(ow_read_rom)"
8x "byte_rd", I get "FF"'s.
What's wrong?
laurentppol wrote:
What's wrong?
- missing: #include "defines.h" in "onewire.c", provided F_CPU is defined in "defines.h" :)
Just for others :), look at the warnings of compiler,not only errors...
Set the "treat warnings as errors" for your compiler. A build with warnings is not a clean build, IMO.
Even if it comes "incompatible pointer type" (missinig typecast?).
But which switch schould I use? My gouru ;P :)
Yes, the point is that a build is only clean if it is really clean. The trouble with allowing some warnings is that sooner or later you will miss a warning that is actually indicating a big problem. All warnings should be removed right away.
In general, "when everything else fails - read the documentation". In this case I'll spoil you and say that you want the
-Wall switch.
And maybe -Werror ;-)
Yes, -Werror was what I was after.
Thanks, Slug! :wink:
