Interrupts under AT32UC3C0512
2 posts / 0 new
I´m trying to setup an interrupt handler to get the results from an external ADC based on the rising edge of a DATA_READY signal connected to a GPIO line
I'm using the following:
#define ADC_RDY_PIN   AVR32_PIN_PA10    // Output signal that indicates ADC conversion completion
ioport_set_pin_dir(ADC_RDY_PIN,  IOPORT_DIR_INPUT);
Disable_global_interrupt();
gpio_enable_pin_interrupt(ADC_RDY_PIN, GPIO_RISING_EDGE);
INTC_init_interrupts();
INTC_register_interrupt(&read_ADC, AVR32_GPIO_IRQ_0 + (ADC_RDY_PIN/8 ), AVR32_INTC_INT0);
Enable_global_interrupt();
The handler is defined as:
__attribute__((__interrupt__)) static void read_ADC( void )
gpio_clear_pin_interrupt_flag(ADC_RDY_PIN);
// Code to read the ADC
With the debugger I can see the handler is called but it looks like it is constantly called and the control is never returned. Everytime I stop the debugger the CPU is always stuck at the default interrupt handler:
static void _unhandled_interrupt(void)
	// Catch unregistered interrupts.
	while (true);
So maybe the problema is somewhere else but I can´t found where :cry:
I´ve tried to change the code to use the EIC instead but withou luck either...
Suggestions are most welcome!
OK, I´ve found the problema. It´s on
INTC_init_interrupts(). I´m also using the TWIM functions which are interrupt based. By calling
INTC_init_interrupts() I was wipping the vector for the TWIM interrupt handler and this is why the CPU was always ending in the default interrupt handler evrytime I trying to use the I2C (TWIM) bus :roll:
