dual USART issue with ATMEGA128
4 posts / 0 new
Hi Guys,
Im working on am irrigation controller project. Using the ATmega128. USART0 is connected to a bluethhoth module and working fine. USART1 is connected to a GSM modem which is breathing but not working properly.
To debug i want to send the commands from bluethhoth interface to the GSM interface, but things are getting messy. chracters keep repeating foreever.
Would appriciate if someone would tell what im doing wrong.
i modifed USART.c ISR routins as follows:
ISR(SIG_USART0_RECV) {
	unsigned char c;
	c = UDR0;					// Get received char
	if (EXC==0xff) //only if global variable is 0xff, exchange data across USARTS
	UART1_putc(c);
	rbuf[r_in & RMASK] = c;		// put in buffer (no check for overflow)
	r_in++;
		// RMASK makes it unnecessary to range limit this
ISR(SIG_USART1_RECV) {
	unsigned char c;
	c = UDR1;					// Get received char
	UART_putc(c);
	rbuf1[r1_in & RMASK] = c;		// put in buffer (no check for overflow)
	r1_in++;		// RMASK makes it unnecessary to range limit this
Thanks Rodney Jr.
Don't call blocking (or any) functions from an ISR. The RECV interrupt should always write to the buffer. Make the choice as to whether to forward the character should be passed on or not later at the point where characters are being extracted from the buffer and used.
Ok,
I have reset the ISR the way they originally were.
someway in main i used this code.
while(2)
				x=UART_rbuflen();
				for (i=1;i<=x;i++)
					UART1_putc(UART_getc);
				x=UART1_rbuflen();
				for (i=1;i<=x;i++)
					UART_putc(UART1_getc);
still does not work.
Any Ideas?
Rodney
This makes no sense. Surely UART1_getc is a function, not a variable.
Steve A.
