include file problem
15 posts / 0 new
I'm trying to write a code using some C function (as I only have "C programming language" knowledge)like clock_t().But when I try to include library function time.h in the code it cause error as no such file in the directory.
Then I find out that avr studio library file arrangement is a little bit different.And also I find two time.h file from this two directory
-->WinAVR-20100110/win32/include
-->WinAVR-20100110/win32/include/machine
when I copy time.h from first directory to the include file directory of avr it find the include but show some error.but when I copy that form second one it show no error or warning.
:shock:
My questions are :?: :?:
    1.Is this kind of header files contains same functions like c?? 2.Is there any way I can use C's header files?
    3.Is there any sources where I can find out what are the functions and its applications of all header files of AVR studio 4 ???
thanks in advance for advices and answer and apology if I talk too much to ask this questions (As I think I do ) 8)
You don't want to be moving system files around. They should be included like this:
#include
It is a header file like any other header file. As such, it should not include functions, only function prototypes.
As I showed above, use <> instead of "". However, the utility of time.h will be limited since it is meant for use in a system that has an OS (that presumably has access to a real time clock).
The avr-libc manual would be a good place to start.
Steve A.
There is no time.h for AVR included in any released version of avr-libc (AFAIK). But there is one in the svn version.
Koshchi;
I think you didn't get my first two question right.
here by function, I mean function prototypes.but the question is a function calling like difftime() will work same in avr as it in C??
I tried with <> also.same problem.
C's header files were kept in different directory,what I wanna ask if I somehow include them(giving the total path of the header file or copy-pest it as I mention before), do they work perfectly for my MCU code???
There is probably a time.h for a Pentium c compiler on your computer, but you want the time.a library with the avr .o object files for difftime all libraried up and ready to link with the atmelstudio compiler. I'd just google for the c source to difftime.c and add it to the project. You'll have to make a timer interrupt that increments a 32 bit time and puts it in a time_t struct. This sort of stuff should probably eventually find its way down into the 8 bit compiler and library, because they do have timers and deal with file systems on sd cards with dates on them. etc.
If you mean can you use library functions from a PC implementation of the C library, No. You need to use an AVR specific library that is specific to your C compiler. If you are using WinAVR (AVR-GCC) you need to use the functions in avr-libc supplied with the compiler. You were directed to the documentation for it in a previous post.
Anklon,
AVR-GCC is built as a 'freestanding' compiler (per ISO/IEC 9899, section 4.6 ).
Standing by itself, many of the standard C libraries are missing.
AVR-Libc provides most of those missing libraries, however the current release does not include the time library.
will be included in the next release.
You can obtain the most recent development version of AVR-Libc via SVN or CVS from
http://savannah.nongnu.org/projects/avr-libc/
Or, you an obtain just the time package from
https://www.avrfreaks.net/index.php?module=Freaks%20Academy&func=viewItem&item_type=project&item_id=3772
I updated it from the SVN head this morning. Type "make help" to get started.
If i use timer interrupt,
is there any way I can restart that timer when i want??
I mean, suppose timer interrupt give an interrupt and it will give me next interrupt after 10 second,
but after 5 second I get some responce from any device and need to restart the timer counting so it will give next interrupt after 10 second from now. How can I do this ???
Stop the timer (i.e. manupulate the prescaler so that the timer does not run) Clean up any interrupts thar are pending. Then just write 0 to the T/C register, and restart the timer.
you mean to reset the prescaler again???
can not understand properly.:/
can you explain in detail ??
There is no reason why you can't use the regular functions. Simply port them from Linux or PC.
You will need to implement the low-level timing functions. e.g. with a 10ms timer interrupt or RTC chip.
Bear in mind that most embedded apps don't have a RTC and don't have the internet and probably want to run off a battery and sleep most of the time.
Hence, no supplied with avr-gcc.
What does the datasheet say in the "prescaler" (Clock Select) table? Something about a certain value indicating "No clock source (Timer/Counter stopped)."?
Yet! See:
http://svn.savannah.nongnu.org/v...
So next time someone labels and takes a copy of AVR-LibC HEAD it will have and associated libc support.
Yet! See:
http://svn.savannah.nongnu.org/v... ... t=avr-libc
Thank you for the heads-up on this, Cliff!
Yet! See:
I wish I said that...
Oh. I did ;-)
