Hi!
I'm wondering if is true that with MPLAB one can use the appropriate printf() function in a PIC. Is it true? In this case with an AVR inside Atmel Studio exist too, without necessity to do you own function? It seems to exist but it doesn't work, at least with an atmega328...
printf() & co.
No idea about MPLAB but printf works very well on all chips with UART functionality.
You have to tell stdio where to send stuff. See attached example from winAvr.
What does innappropriate mean
What does 'it does not work' mean? (many things do not work)
Choosing the apprpriate format may be very inappropriate if one wants to display conversions at least :
ex, on a PC
$ cat a.c #includeint main() { int8_t c='U'; printf("%c %x %d\n",c,c,c); }
The user manual:
The example in user manual (for which John also posted the files above):
I have some troubles to implement this. I mean, there a FILE pointer initialization which i don't understand how to implement in a USART function.
What I wrote is that:
void USARTWriteString(int n, char* data) { unsigned int cyc=0; for (cyc=0; cyc
and
void USARTReadString(int n, char* stringa) { int i; for (i=0; i
and I initialize with:
void USARTInit(uint16_t baud) { //Set Baud rate UBRR0 = 103; //= F_CPU/(16*baud) - 1; /*Set Frame Format >> Asynchronous mode >> No Parity >> 1 StopBit >> char size 8 bit */ UCSR0C|=(1<<UCSZ00)|(1<<UCSZ01); //Enable The receiver and transmitter UCSR0B|=(1<<RXEN0)|(1<<TXEN0); }
And the character managing, like this:
char USARTReadChar() { //Wait until a data is available while(!(UCSR0A & (1<<RXC0))) { //Do nothing; you can BLINK a LED here :P } //Now USART has got data from host //and is available in buffer return UDR0; } void USARTWriteChar(char data) { //Wait untill the transmitter is ready while(!(UCSR0A & (1<<UDRE0))) { //Do nothing } //Now write the data to USART buffer UDR0=data; }
All is wrote with the data sheet help. But There's a lot of software abstraction in your guide that I cant orientate myself. Can I have a little more help? :)
But the whole point of using printf is so that you don't need to write the string routines, you only need a getchar and a putchar routine. Did you not at all look at the pages linked to above?
Just checking but did you read this example in the user manual:
Ignore the LCD stuff and concentrate on UART alone. Therefore it suggests you need one character input function and one character output function. You don't need to write character string functions because you get all that "for free" when you wire up to stdio. You then get printf, scanf, gets, puts and so on. So as the example shows the prototype for the character output function must be:
int uart_putchar(char c, FILE *stream);
and the input function you provide must have the interface:
int uart_getchar(FILE *stream);
So forget your USARTWriteString(), forget your USARTReadString(). You still need your USARTInit() and you must modify your single character send/receive routines as follows:
int USARTReadChar(FILE *stream) //Wait until a data is available while(!(UCSR0A & (1<<RXC0))) { //Do nothing; you can BLINK a LED here :P } if (UCSR0A & _BV(FE0)) return _FDEV_EOF; if (UCSR0A & _BV(DOR0)) return _FDEV_ERR; //Now USART has got data from host //and is available in buffer return (int)UDR0; } void USARTWriteChar(char data, FILE *stream) { if (data == '\n') { USARTWriteChar('\r', stream) } //Wait untill the transmitter is ready while(!(UCSR0A & (1<<UDRE0))) { //Do nothing } //Now write the data to USART buffer UDR0=data; }
Finally you are in a position to write main():
#includeint USARTReadChar(FILE *stream); void USARTWriteChar(char data, FILE *stream); FILE uart_str = FDEV_SETUP_STREAM(USARTWriteChar, USARTReadChar, _FDEV_SETUP_RW); char buff[20]; int main(void) { USARTInit(9600); stdout = stdin = &uart_str; printf("My God, it works\n"); while(1) { gets(buff); puts(buff); } }
fgets() may be "safer" than gets() (which reads stdin by implication) as it lets you specify the buffer size:
while(1) { fgets(buff, 20, stdin); puts(buff); }
The '\n' handling is different though.
Just checking but did you read this example in the user manual:http://www.nongnu.org/avr-libc/u...
int uart_putchar(char c, FILE *stream);and the input function you provide must have the interface:
int uart_getchar(FILE *stream);So forget your USARTWriteString(), forget your USARTReadString(). You still need your USARTInit() and you must modify your single character send/receive routines as follows:
int USARTReadChar(FILE *stream) //Wait until a data is available while(!(UCSR0A & (1<<RXC0))) { //Do nothing; you can BLINK a LED here :P } if (UCSR0A & _BV(FE0)) return _FDEV_EOF; if (UCSR0A & _BV(DOR0)) return _FDEV_ERR; //Now USART has got data from host //and is available in buffer return (int)UDR0; } void USARTWriteChar(char data, FILE *stream) { if (data == '\n') { USARTWriteChar('\r', stream) } //Wait untill the transmitter is ready while(!(UCSR0A & (1<<UDRE0))) { //Do nothing } //Now write the data to USART buffer UDR0=data; }Finally you are in a position to write main():
#includeint USARTReadChar(FILE *stream); void USARTWriteChar(char data, FILE *stream); FILE uart_str = FDEV_SETUP_STREAM(USARTWriteChar, USARTReadChar, _FDEV_SETUP_RW); char buff[20]; int main(void) { USARTInit(9600); stdout = stdin = &uart_str; printf("My God, it works\n"); while(1) { gets(buff); puts(buff); } } fgets() may be "safer" than gets() (which reads stdin by implication) as it lets you specify the buffer size:
while(1) { fgets(buff, 20, stdin); puts(buff); }The '\n' handling is different though.
It works. :D
Your example with the gets part lead me to understand well the behaviour.
I was missing the uart_str initialization mechanism. Thanks to you and google for other examples for understanding the stream inizialization, now it works. ;) Thanks!
And with that I'll move this thread to GCC Forum as it's only relevant to the avr-gcc compiler.
I am wondering if it's possible to implement the floating support of the printf. I know that I neet to add an option like "-lprintf_flt" but since i'm using AVR Studio 6 and I'm not real expert in the exact toolchain mechanism, I dont where to go to tell to implement the floating conversion.
If you look to the Solution Explorer and right click libraries as shown in the first picture below you should reach the dialog in the second picture. Make sure the printf_flt option is selected. Then in the Project Properties under AVR/GNU Linker look for "General" and in that make sure the last option (that mentions vprintf is ticked) as shown in the 3rd picture.
So 17 days ago we gave you a WORKING example of printf and you still can't get it to work? :roll:
What if I ask to Clawson if it is normal that I dont have the "Libraries" menu? I tried to find something in menus, in vain. I mean, searching on google and here there's a lot about my problem, but how can I modify my compiler option adding the fprintf_flt option if do not find the graphical path to follow? I've Atmel Studio 6, I suppose that Clawson is using the 5 or another version with a difference on the gui.. (?)
Of course. As mentioned, similar with gcc for AVRs.
I have used XC8 and SDCC PIC toolchains under MPLABX and printf() works seamlessly on both. What is more, if you run the MPLABX PIC simulator, then output of printf() is redirected to an MPBLABX console (that feature is not present in AS4, not sure about AS6).
OP wrote:if is true that with MPLAB one can use the appropriate printf() function in a PIC. Is it true?
Cool.
I saw an example about printf with mplab. He didn't used the FILE macro as we did. Is it possible?
Is it possible?
MPLAB/MPLABX is just an IDE(like Eclipse or VS). It does not printf. It is the library that does the printf job. If you want to know the details of the libraries provided with XC8/C18/SDCC/redlib/newlib/avrlibc, whatever, for this or any other toolchain then you should search the documentation.
I do not remember the details of XC8's style, but with SDCC it is very much the same as with AVRs. You must initialize USART registers, FILE* stdout stream variable:
//Configure printf to work with USART usart_open( USART_TX_INT_OFF & USART_RX_INT_OFF & USART_BRGH_HIGH & USART_SINGLE_RX & USART_EIGHT_BIT & USART_ASYNCH_MODE, 1249); stdout = STREAM_USER; //initialize FILE* stdout printf("\n\rUser stream on UART0 at 9600, 8N1 \n\r");
and provide some kind of putchar() implementation (polled or via IRQs)
Great! I've added "-lprintf_flt" in "Other Linker Flags" instead using your add library menu (which I don't have... why? I'm using AS6)
Well, before the printf stuff my code was something like 1KB. Now we are near to 4.5KB :P
Thanks again.
AS6 doesn't do it either. As you say it's not really something supplied by the IDE (though that has to have an interface to hook into). It requires a copy of libc.a with a special implementation of printf() that, instead of outputting to LCD or UART or whatever outputs to some stream that can be input to the debugger UI. Such a "hosted lib" does not exist for AVR8 though I suppose it's within Atmel's remit to add both the AVR and IDE side of things if they wanted to offer it assuming the JTAG protocol implemented by Atmel's tools has a supporting comms channel in that direction (though again maybe it could be added to the firmware of the various ICEs?).
Someone knows why when I put from keyboard a "\n" or a char in general in the terminal, the code above is looping?
Here the code (running on atmega328 with AS6):
scanf("%d %d;", &calib, &calib_amb); printf("\n ddc %d", calib); printf("\n str %d", calib_amb);
I remember that on PC I solved this using sscanf parsing whenever I've wrote in stdin to a string and working on it.
But here, there's a different way from this, to receive from a more "secure" terminal? For the terminal I'm using the arduino one because I'm lazy and seems to work well :D (it works, except for this bug, when I set the autosend of "\n" when I press Enter). But as I said, if I write a "\something" or a char, is start looping printing always the last values of calib and calib_amb.
As the same way, when I wrote:
scanf("%1.2f %1.2f", &calib, &calib_amb); printf("\n ddc %1.2f", calib); printf("\n str %1.2f", calib_amb);
definitely won't work, in the sense that those 2 vars are still "0.00" and is looping without sending anything. Examples on web and used in previous PC software and books (used in an exam for the polytechnic) seems to be like my code. So I think that is something with stdin vector recalled with posts above...
Clarifications are welcome.
EDIT: I solved with that
scanf("#&37;s", incoming); calib = atof(incoming); scanf("%s", incoming); calib_amb = atof(incoming);
But I still wondering what is wrong...
Meanwhile, I noticed that (I was thinking that this error wasn't present before): at line
static FILE mystdout = FDEV_SETUP_STREAM(USARTWriteChar, USARTReadChar, _FDEV_SETUP_RW);
AS6 gives "Initialization from incompatible pointer type" but everything is working well.
NOTE: I've to say that I receiving nonsense warning, i.e. from eeprom that receive an int intead of float* (but address should be an int, and in fact it is still working correctly) and removing the "static" from the FILE row mentioned above the eeprom (which don't use the IO at all) stop to give errors. Of course, the warning of the FILE row is still appearing. And of course, with re-inserting the "static" the eeprom is still w/out warnings. wtf? Damn it, I'm an electronic, not a programmer xD Is AS6 compiling basing on its humor?
Either one of USARTWriteChar or USARTReadChar really does not have the same function pointer type as expected by the struct initialisation or the copy seen at the time of invocation of FDEV_SETUP_STREAM is wrong. For example if I write:
float USARTWriteChar(int, long, char); short USARTReadChar(char *, int, float); static FILE mystdout = FDEV_SETUP_STREAM(USARTWriteChar, USARTReadChar, _FDEV_SETUP_RW);
Then I get:
C:\Documents and Settings\asl\My Documents\Atmel Studio\test\test\test.c(8,15): initialization from incompatible pointer type [enabled by default] C:\Documents and Settings\asl\My Documents\Atmel Studio\test\test\test.c(8,15): (near initialization for 'mystdout.put') [enabled by default] C:\Documents and Settings\asl\My Documents\Atmel Studio\test\test\test.c(8,15): initialization from incompatible pointer type [enabled by default] C:\Documents and Settings\asl\My Documents\Atmel Studio\test\test\test.c(8,15): (near initialization for 'mystdout.get') [enabled by default]
that's because the functions have the wrong interface. If I correct that to be:
int USARTWriteChar(char, FILE *); int USARTReadChar(FILE *); static FILE mystdout = FDEV_SETUP_STREAM(USARTWriteChar, USARTReadChar, _FDEV_SETUP_RW);
all the warnings go away. The point being that the write/put function must return int and take a char and a pointer to FILE while the read/get function must return an int and take a pointer to FILE.
Reviewing this thread I now see the error. I had suggested:
void USARTWriteChar(char data, FILE *stream) { ... }
that is incorrect. It should be:
int USARTWriteChar(char data, FILE *stream) { ... }
The routine should return 0 if the character could be written or non-zero if it could not. I guess this might occur if, for example, you implemented a time-out within the function and the UART did not become ready before the time-out occurred. In the absence of such a mechanism just always return 0. That is:
int USARTWriteChar(char data, FILE *stream) { ... return 0; }
The user manual:http://www.nongnu.org/avr-libc/u...
I was wondering how streams interact with my uart (or whatever) IO function. EEverything is explained in those pages and can be applied, ok. But if I want to know just how the FFILE*stream argument interact with the argument char of usartreadchar(), for example, should I learn how those "Operating System" function work? (of course I'm talking about to those declarations that I need to implement, since there's no OS on device). Can I know if in code below, if there's an upper function that call char to *stream, since there no clear relation with those 2 arguments.
#includestatic int uart_putchar(char c, FILE *stream); static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE); static int uart_putchar(char c, FILE *stream) { if (c == '\n') uart_putchar('\r', stream); loop_until_bit_is_set(UCSRA, UDRE); UDR = c; return 0; } int main(void) { init_uart(); stdout = &mystdout; printf("Hello, world!\n"); return 0; }
Who tells the uart_putchar to put c to stream? Who's the witch that done that? Should her burn? I hope not!
I understand that &mystdout is a reference to a stream that uses uart_putchar and is called for every char present in printf (since printf() manipulates stdout stream initilizet at bottom of the code, as defined in stdio.h, I think). But when we go to HW level, like using UDR0, I just lose the relation bitween &mystdout, printf and FILE *stream (in which should be a parameter coming from &mystdout) but not present in uart_putchar() or whatever...
I repeat: I don't need help to implement this, since I understand how to do this, but I ask if possible if I can have a little help to understand what is hidden in the code.
EDIT: @clawson: I saw just now what you just answered. Yeah, you're right and thanks.
But I noticed something weird: I've compiled with those errors, make modifications as you said, everything work. But sometimes, indipendently if I've modified code or not, gives me same init error, bringing me to this line: (but still work)
static FILE mystdout = FDEV_SETUP_STREAM(usartwritechar, usartreadchar, _FDEV_SETUP_RW);
§Look at this as an excellent opportunity for an exploratory adventure!
The sources for avrlibc are perfectly accessible here: http://savannah.nongnu.org/proje...
Start with looking at what hides behind FDEV_SETUP_STREAM and then look at what printf does (or rather sprintf, but you will discover that yourself). These are the two things that you actually utilize in your source, and there is no witchery in the avrlibc sources. It might utilize some aspects of C that you have not encountered (I'm sure you'll hit "function pointers" for this stream case), but everything you do not understand yet is an opportunity to learn something new!
:D
EDIT:
No-one. You got that wrong. "The stream" tells some putchar to put the character somewhere. In the case here it is something inside printf that tells uart_putchar to output the character through the UART.
Soewhere inside printf (or sprintf, or...) there is code that picks up the FILE stdout. This (as an examination of the type FILE and the macrto FDEV_SETUP_STREAM will reveal) is a struct that holds pointers to the put and get functions (and some other stuff, like the flags you send as a third parameter to FDEV_SETUP_STREAM). When you call prints it will evetually lead up to a piece of library code that picks up stdout, get the pointer to the put-function and call it for each character printf needs to output.
Again, the details are in the avrlibc sources, which I linked to above.
I forget one thing:
Functions like ReadString and WriteString, without stream initialisation, in your opinion, for a basic point of view, are fine? (they actually work)
EDIT: thanks JohanEkdahl, I've read your post after. You lead me to a foundamental conclusion. That the second argument (FILE *) is not essential to the function but only to the initialization of stream and print/scanf for some correct rule. The readchar(char, FILE*) is called by scanf() and parsing to it the char. The FILE* could be there only because printf (& Co) are made to parse a FILE pointer, even if it is not used (so we can compile w/out errors).
Am I slighty right?
Some time back in another thread of mine Cliff posted this snippet for me:
// Interrupt EXT1 - RS232 TX to pc
ISR(INT1_vect){
void uart_init(void);FILE uart_str = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE);
I still do not understand what the "FILE uart_str ....." stuff,
and the
really mean, but with Johans link I have some good reading to get started on.
THis thread has also helped quite a bit too.
Like Johan says you can answer a lot of this by studying the sources but first it probably helps to know these facts (I'll only deal with output but input is generally symmetric with this):
1) highlevel functions like printf and puts are all ultimately built on top of putcchar().
2) putchar is simply:
#define putchar(__c) fputc(__c, stdout)
3) a FILE is basically just a struct{} that holds information about an open file. While an embedded AVR does not have filing system as such and the concept of files on disk (though this can be added with things like an SD/MMC card) just as on your PC where COM3 is effectively a "file" so the UART on your AVR can also be treated as a file. At the end of the day a "file" is nothing more than a serial stream of data anyway (in C++ the concept of filing is even called serialization) so a common structure can hold the information for any of these things. The definition of FILE is:
/* * This is an internal structure of the library that is subject to be * changed without warnings at any time. Please do *never* reference * elements of it beyond by using the official interfaces provided. */ struct __file { char *buf; /* buffer pointer */ unsigned char unget; /* ungetc() buffer */ uint8_t flags; /* flags, see below */ int size; /* size of buffer */ int len; /* characters read or written so far */ int (*put)(char, struct __file *); /* function to write one char to device */ int (*get)(struct __file *); /* function to read one char from device */ void *udata; /* User defined and accessible data. */ };
Note towards the end there two function pointer definitions for put and get functions.
4) When you use FDEV_SETUP_STREAM it is defined as:
#define FDEV_SETUP_STREAM(p, g, f) \ { \ .put = p, \ .get = g, \ .flags = f, \ .udata = 0, \ }
So when you write:
what you are really saying is:
static struct __file mystdout = { .put = USARTWriteChar, .get = USARTReadChar, .flags = (0x0001|0x0002), .udata = 0, };
(BTW note you don't need "static" above as it's provided as part of "FILE"). This is creating a FILE structure in the RAM of your AVR and is setting the put and get function pointers to your provided functions.
5) stdout is just a pointer to FILE that's held in RAM which is why you use:
stdout = &mystdout;
6) finally understand what fputc() does:
int fputc(int c, FILE *stream) { if ((stream->flags & __SWR) == 0) return EOF; if (stream->flags & __SSTR) { if (stream->len < stream->size) *stream->buf++ = c; stream->len++; return c; } else { if (stream->put(c, stream) == 0) { stream->len++; return c; } else return EOF; } }
Remember that the flags were set to 0x0001 | 0x0002 which are found in:
#define __SRD 0x0001 /* OK to read */ #define __SWR 0x0002 /* OK to write */ #define __SSTR 0x0004 /* this is an sprintf/snprintf string */ #define __SPGM 0x0008 /* fmt string is in progmem */ #define __SERR 0x0010 /* found error */ #define __SEOF 0x0020 /* found EOF */ #define __SUNGET 0x040 /* ungetc() happened */ #define __SMALLOC 0x80 /* handle is malloc()ed */
So __SWR is set. Therefore the first if() test is non-zero and the function does not return. __SSTR is not set as you want output to the put() function, not a buffer in memory so the second if() clause is skipped. It therefore will execute the final else() clause. So it calls the stream->put() function.
You now have all the pieces of the jigsaw. Put them together and you will see exactly how printf("hello") works.(*)
(*) actually there's one more thing you may want to know. If you use printf("x = %d", x) the compiler calls the full version of printf() as it needs to process the placeholder and use the argument list, but if you just call printf("hello") with a fixed string the compiler is smart enough to know that it can simply use puts("hello") - so it does. None of this really matters though, they all ultimately call putchar().
EDIT: BTW looking at the source printf(...) is effectively vfprintf(stdout,...) and within vfprintf() the output is done using putc(stream, ...). So it's not exactly using putchar() but bypassing it to use putc(stream, ...) directly where stream=stdout.
Oh, that is why for printing and reading only chars and managing them, for simplicity (and also +-1kB less of flash used) I use my USART string functions (https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=134734). Prtinting a variable instead a only sequence of chars, is recalling the more complex functions, as you said, so for now I exploit this to avoiding headache.
Clawson, without your help I couldn't understand that type of documentation. Thank you. At least I know where to start.
I stayed up too late last night to dig the sources and write what is in this and the next post. I'd be happy if the OP, Jim and Cliff (with their different experiences) look this through for things less clear and the obligatory typos. I'll move it to the Tutorials forum eventually.
Here is the first part (the "howto"):
Getting printf working [gcc/avrlibc]
This is a tutorial [in labour] on how to get print working in avr-gcc/avrlibc.
It is a short exemplified alternative to the primary documentation which you can find e.g. here:
Introduction
Out of the box avr-gcc will not direct printf output so any specific place. It can not know if you want the output to e.g. the UART or to an LCD diplay or.. What printf supplies is all the funky stuff needed to convert different kinds of data to displayable format (i.e. converting it so strings) and a generic infra-structure to send it to some output hardware. What you will need to supply is the last link in the chain - something that outputs a character to the place where you want it to go.
You do this by
1. Writing an output function. It must always have the following prototype:
int putchar_function(char c, FILE *stream)
You can give any name you want to this function, but it must follow the prototype above regarding parameters and return type.
2. Create a FILE variable (using the predefined FDEV_SETUP_STREAM macro) and make the predefined stdout variable point to it.
These two rather simple things is all there is to it.
Example
This is a slightly reworked variant of the example in the avrlibc documentation.
The output function takes the character it receives as an input parameter and sends it through the UART:
int uart_putchar(char c, FILE *stream) { // Wait until the UART is free loop_until_bit_is_set(UCSRA, UDRE); // Send the character through the UART UDR = c; // Done! return 0; }
Since we are using the UART it of-course needs to be initialized, set to transmit at a certain speed etc. This is not shown here.
<<Perhaps finish off with a complete program for e.g. the ATmega328>>
Now that we have an output function we can use that to set up the stream. This process is simplified by using a macro FDEV_SETUP_STREAM that is predefined in avrlibc. The macro takes three parameters:
FDEV_SETUP_STREAM(put, get, rwflag)
The first parameter put is the putchar function you have written.
The second parameter is used if you want input streams using e.g. scanf. In that case you need to write a getchar function, just like you wrote a putchar function for the output stream. The third parameter is used to tell avrlibc if you want the stream to handle output, input or both.
The macros is used to initialize a FILE variable. In our example it goes like this:
FILE my_stdout = FDEV_SETUP_STREAM( uart_putchar, NULL, _FDEV_SETUP_WRITE);
The _FDEV_SETUP_WRITE tells avrlibc that we want only output through the stream. Since we do not want any input we have written no getchar functino, so we pass NULL as the second partameter.
The last thing we need to do is to set stdout (the predefined standard output stream ) to point to our FILE variable:
stdout = &my_stdout;
With this we can now code things like
printf("Hello stdio!");
or
int meaning_of_life = 42; printf("The meaning of life is #i", meaning_of_life);
[TOBE]Here is a complete program, for an ATmega328, doing what is described above:
<<Complete example>>
[/TOBE]
Behind the scenes of printf [gcc/avrlibc]
How does does the streams in avrlibc work? What goes on when you do things like
Based on the previous tutorial, we'll now look behind the scenes.
IMPORTANT NOTE ON PREREQUISITES: To fully understand this you will need to know about the C concept of "function pointers". Without understanding those parts of this tutorial might not make sense. This tutorial will simply assume you already have that knowledge. It is outside of the scope of this tutorial to teach "function pointers in C".
The overall structure
[TODO]Some work needed here[/TODO]
Application --> printf and friends --> putchar --> hardware peripheral
Expanding FDEV_SETUP_STREAM
The FDEV_SETUP_STREAM macro is defined like this in avrlibc:
So when you code
the compiler will actually see
{ .put = uart_putchar, .get = NULL, .flags = _FDEV_SETUP_WRITE, .udata = 0, }
What we actually did in our example was
and after macro expansion the compiler will see this:
FILE my_stdout = { .put = uart_putchar, .get = NULL, .flags = _FDEV_SETUP_WRITE, .udata = 0, }
To understand this, we need to look at how the type FILE is actually is defined:
#define FILE struct __file
So, now we need to take a look at the __file struct definition. I show it here somewhat "cleaned up" as compared to the actual definition in the sources:
This struct keeps all the essential data that avrlibc needs to keep about a certain stream. Not all members of the struct are used in every scenario, but you should note that among the members in this struct there are some whose names should look slightly familiar: flags, put, get and udata.
We are finally done, and the result of our digging is this: The code
creates a __file struct and initializes some of its members. The thing of central interest to us is that the member put (which is a function pointer) is initilized to point to our uart_putchar function.
Dissecting printf
Now we can turn to the call to printf. Remember the meaning of life..
When we call printf it will actually call another function internal to avrlibc: vfprintf. Anyone calling vfprintf must pass as a parameter the stream which vfprintf should use, and printf passes the C standard output stream, stdout. Yes, the very one we did set up above!
The vfprintf function will in turn do essentially two things:
1. Use the parameters (in our case the format string, and one additional parameter) into one string. I will not go into details on this here since it is not central, but the end result is the string "The meaning of life is 42".
2. Take the characters, one by one, and call a function putc. This putc function takes two parameters: The stream to use, and one character to put to that stream.
We now encounter some tricky stuff, but for our purposes we do not need to dig into the details: The putc function is actually written in assembler. It is trivial. All it does is to pass on control to yet another function calle fputc. This is an ordinary C function. It contains some code for maintaining information on the "inner state" of a stream, and some error handling. Here it is in full:
For our purposes, understanding how the bits and pieces of stream output all fit together, we can actually reduce it to this:
int fputc(int c, FILE *stream) { if (stream->put(c, stream) == 0) { stream->len++; return c; } else return EOF; }
The absolutely central part of this is
The stream parameter has come all the way from when printf called vfprintf and in that case it is actually stdout. Now, remember that we set it to point to a struct we created, and that this struct has a member called get. That member is a function pointer which refers to the my_putchar that we wrote.
Finally we are at the end of the road!
actually calls our my_putchar. Our code in that function outputs the character to the UART.
Now, you might wonder why the putchar function actually needs the FILE parameter. We certainly are not using it in our implementation. The answer is that such things happen in a "framework" where things will be used in different ways at different times. Other implementations might want to do some manipulation of the FILE structure. Making it a parameter allows these implementations to do so. Our implementation does not oeed to, but still has to receive the parameter. We simply will not touch it after that.
Phew! If you at this time is somewhat confuse, or feel your head is spinning, then that is quite okay. Take a break and then do something else. Return here in a day or three and re-read. Hopefully things will clear up a bit with a few re-reads.
And if you still have no clue about "function pointers in C" then you have chose the wrong order of learning things. Don't get me wrong here! You can still use output streams. You just can't understand how they function internally.
And a little addition about code size using various forms of printf
#include#include #include "project_definitions.h" #include "USART0_s.h" #include "USART1_s.h" #define PI 3.141593 FILE com0_str = FDEV_SETUP_STREAM(usart0_putchar, usart0_getchar, _FDEV_SETUP_RW); FILE com1_str = FDEV_SETUP_STREAM(usart1_putchar, usart1_getchar, _FDEV_SETUP_RW); void printf_test_init (void) { stdout = stdin = com0; usart0_init(); usart1_init(); } int main(void) { printf_test_init(); //No floating point support printf("Printing on com 0\r\n"); // Using stdout 600 bytes fprintf(com0, "Printing on com 0 with fprintf\r\n"); // 780 bytes fprintf(com1, "Printing on com 1 with fprintf % d\r\n",12345); // 2250 bytes //With floating point support fprintf(com0, "Printing on com 0 with fprintf % f\r\n",1.23456); // 3882 bytes fprintf(com1, "Printing on com 1 with fprintf % f\r\n",PI); // 3972 bytes for(;;); }
Johan, I will have to look at this again in the morning. From what I just read I think I hurt myself. ;)
YOu might want to change 'prototype' :
Code:
int putchar_function(char c, FILE *stream)You can give any name you want to this function, but it must follow the prototype above regarding parameters and return type.
I will follow protocol ;)
Code:
It IS a function prototype, "protocol" would be totally inappropriate in this case.
It is like asking him for replacing "steering wheel" by "handle" in a tutorial about car driving (replacing the correct specific name by something that is distantly related).
@Johan: I'm glad that something new useful is born from my thread. Thank you for help.
Stefan
In my world a prototype is the 'test unit' and usually has bugs in it where as a 'protocol' is a strict set of rules to follow. Like a communications 'protocol'.
Thanks for explaining
That might be so, but you have entered "the C world". "Function prototype" is well established C terminology. A "function head without a body" is called a "function prototype". It is not something I made up:
http://en.wikipedia.org/wiki/Fun...
http://www.cprogramming.com/tuto...
http://cplus.about.com/od/glossa...
http://www.codeproject.com/Artic...
"Prototype" in programming is the documentation of interface to a function. In general .h files are full of extern variable declarations and function prototypes. It's simply a different meaning of the word which also means "first test version" when applied to electronics/computer hardware.
I suppose you could use the term "function declaration" instead of "prototype" or even just "API".
Or "funtion head", or "function header" perhaps. But "prototype" is the first term for this in my world.
I hear what you are saying all of you. I was merely posting an opinion based on Johan asking that the OP myself and Cliff take a look at his budding tutorial
Sorry I said anything
Let's look at a couple of dictionary-type definitions:
pro·to·type (prt-tp)
n.
1. An original type, form, or instance serving as a basis or standard for later stages.
2. An original, full-scale, and usually working model of a new product or new version of an existing product.
3. An early, typical example.
4. Biology A form or species that serves as an original type or example.
Adj. 1. prototypical - representing or constituting an original type after which other similar things are patterned; "archetypal patterns"; "she was the prototypal student activist"
Definition of PROTOTYPE
1: an original model on which something is patterned : archetype
2: an individual that exhibits the essential features of a later type
3: a standard or typical example
4: a first full-scale and usually functional form of a new type or design of a construction (as an airplane)
While "early" and "working model" are indeed mentioned, where is the implication of "buggy"? The first definition, from two sources, seems to perfectly describe the C function prototype, and the standards-makes seem to have picked the correct word to describe the facility.
Maybe not but have you ever created a (physical) prototype that didn't expose at least one flaw in either the electronic or software design? ;-)
Well, I have been making some progress, but I am back at confused.
I can get the LCD to init. I get the screen to clear, and the cursor in the upper left so the comms are good. The fprinf is where I am stuck. Just want to see hello world and stop.
I also get two warnings as well as seen below:
#include#include #include #include "lcd.h" FILE lcd_str = FDEV_SETUP_STREAM(lcd_puts, NULL, _FDEV_SETUP_WRITE); void avrinit(void) { DDRA = 0xFF; //porta all outputs for LCD } int main(void) { avrinit(); lcd_init(LCD_DISP_ON_CURSOR_BLINK); stdout = &lcd_str; fprintf(stdout,"Hello world!\n"); while(1) { //TODO:: Please write your application code } }
Mega2560 @4MHZ
Here is the warning:
Could not edit the above post so I'll continue here.
I cannot for the life of me figure out the FILE xxx = FDEV etc.
So I took some code out of TEST_LCD and it worked.
Here is my new file:
#include#include #include #include #include "lcd.h" void avrinit(void) { DDRA = 0xFF; //porta all outputs for LCD } int main(void) { avrinit(); lcd_init(LCD_DISP_ON_CURSOR_BLINK); /* put string to display (line 1) with linefeed */ lcd_puts("LCD Test Line 1\n"); /* cursor is now on second line, write second line */ lcd_puts("Line 2"); while(1) { //TODO:: Please write your application code } }
Works for now, but I am going to have to re-read Johans posts a few more times
In your program two posts above a declaration or definition of lcd_puts is missing.
Surely there'd be a declaration in lcd.h
The warning about incompatible pointer will be because the interface is different. I bet the lcd_putchar is not designed to take a stream pointer as the second parm (even if it isn't used).
You only need these lines of code:
#include "lcd.h" int main(void) { lcd_init(LCD_DISP_ON_CURSOR_BLINK); /* put string to display (line 1) with linefeed */ lcd_puts("LCD Test Line 1\n"); /* cursor is now on second line, write second line */ lcd_puts("Line 2"); while(1) { //TODO:: Please write your application code } }
1. avrinit() is superfluous. lcd_init() does the initalisation
2. since we are not referencing DDRA, we don't need
3. since we are not referencing printf etc, we don't need
4. since we are not referencing uint8_t etc, we don't need
5. since we are not referencing PROGMEM etc, we don't need
Untested.
There is absolutely no harm in including those standard header files. I just thought it useful to point out the simplicity of a module program.
Personally, I would try to use
#include#include #include #include "lcd.h" FILE stdlcd_struct = FDEV_SETUP_STREAM(lcd_putchar, NULL, _FDEV_SETUP_WRITE); int main(void) { lcd_init(LCD_DISP_ON_CURSOR_BLINK); stdout = &stdlcd_struct; fprintf(stdout, "Hello world!\n"); while(1) { //TODO:: Please write your application code } }
Also Untested. It should 'work' but give a warning about the type of lcd_putchar(). i.e. you could use an intermediate " FILE* " version of lcd_putchar()
However some of those headers will be required to make your stdio/fprintf version work. BTW you do know that printf() is shorthand for fprintf(stdout,...)?
Sorry, it was naughty to post Untested code. So I have added the 'dummy' function to keep the Compiler happy:
#include#include #include #include "lcd.h" // dummy "std" version of the LCD output function int stdlcd_putc(char c, FILE *fp) { lcd_putc(c); return 0; // seems to want 0 for GOOD } FILE stdlcd_struct = FDEV_SETUP_STREAM(stdlcd_putc, NULL, _FDEV_SETUP_WRITE); int main(void) { lcd_init(LCD_DISP_ON_CURSOR_BLINK); stdout = &stdlcd_struct; fprintf(stdout, "Hello world!\n"); while(1) { //TODO:: Please write your application code } }
Don't get me wrong. Including loads of standard headers does no harm. I just thought that I would show what a Compiler needs. i.e. sufficient info about external functions and structures.
Note that you can use several equivalent sequences:
// longwinded way of doing things: stdout = &stdlcd_struct; fprintf(stdout, "Hello world!\n"); // print to the 'regular' standard output stream: stdout = &stdlcd_struct; printf("Hello world!\n"); // just print to a specific stream: fprintf(&stdlcd_struct, "Hello world!\n");
Not in the latest attempt but scroll up to see that the ultimate goal here seems to be to get (f)printf working.
I have subsequently tested the code examples with AS6 that I posted earlier.
And you don't need any other header files. Each module "knows" what is necessary to compile. The linker puts it all together.
Well the ultimate goal was to actually get printf, but where I started getting confused was in the STDIODEMO project there were a couple of lines that I thought answered my questions on how do you output to an LCD, or to the UART when you have both connected.
FILE uart_str = FDEV_SETUP_STREAM(uart_putchar, uart_getchar, _FDEV_SETUP_RW); FILE lcd_str = FDEV_SETUP_STREAM(lcd_putchar, NULL, _FDEV_SETUP_WRITE); . . . . stdout = stdin = &uart_str; stderr = &lcd_str;
This leads me to believe that you can have two outputs. One for the UART, and the other for a local LCD. But lets forget about that right now. I have been concentrating on the LCD stuff, along with a pushbutton, but thats for another thread.
Here is what I have right now and it indeed does work:
#include#include #include #include #include "lcd.h" void avrinit(void) { DDRA = 0xFF; //porta all outputs for LCD } int main(void) { avrinit(); lcd_init(LCD_DISP_ON_CURSOR_BLINK); /* put string to display (line 1) with linefeed */ lcd_puts("LCD Test Line 1\n"); /* cursor is now on second line, write second line */ lcd_puts("Line 2"); while(1) { } }
I get two lines that read exactly like what is in the code. I was simply trying to use the printf statement and ran into some issues that I will have to work out with the advice given above.
What is my short term goal? To get printf to work sending text to an lcd. Then to the UART, which I have done already, and then finally a selective where depensing on STDOUT, or STDERR pick which way the data goes. I guess I could simply use printf for the uart and keep lcd_puts for the LCD. Probably much easier.
The long term is to have a pushbutton that will change what is on the display. This is what I was working on late least night with Deans Bit manipulation tutorial.
Thanks.
I'm using the lcd files from stdiodemo in my current project https://www.avrfreaks.net/index.p...
and added to lcd.h
#define lcd (&lcd_str) extern FILE lcd_str;
and in my init file
FILE com0_str = FDEV_SETUP_STREAM (usart0_putchar, usart0_getchar, _FDEV_SETUP_RW); FILE lcd_str = FDEV_SETUP_STREAM (lcd_putchar, NULL, _FDEV_SETUP_WRITE);
I did something similar on a project where I used my own display pcb with 5 7x5 led displays (just had to supply the display output function)
#define display (&display_str) extern FILE display_str; . . . FILE display_str = FDEV_SETUP_STREAM (display_putchar, NULL, _FDEV_SETUP_WRITE);
And in another project with 4 usarts
FILE com0_u_str = FDEV_SETUP_STREAM (NULL, usart0_unbuffered_getchar, _FDEV_SETUP_READ); FILE com0_str = FDEV_SETUP_STREAM (usart0_putchar, usart0_getchar, _FDEV_SETUP_RW); FILE com1_u_str = FDEV_SETUP_STREAM (NULL, usart1_unbuffered_getchar, _FDEV_SETUP_READ); FILE com1_str = FDEV_SETUP_STREAM (usart1_putchar, usart1_getchar, _FDEV_SETUP_RW); FILE com2_u_str = FDEV_SETUP_STREAM (NULL, usart2_unbuffered_getchar, _FDEV_SETUP_READ); FILE com2_str = FDEV_SETUP_STREAM (usart2_putchar, usart2_getchar, _FDEV_SETUP_RW); FILE com3_u_str = FDEV_SETUP_STREAM (NULL, usart3_unbuffered_getchar, _FDEV_SETUP_READ); FILE com3_str = FDEV_SETUP_STREAM (usart3_putchar, usart3_getchar, _FDEV_SETUP_RW);
Jim's error is that he used:
I would respectfully suggest you would get more mileage from:
The whole point here is that the stream function only has to put (and in the case of UART possibly also get) one character at a time. Sure, once you have connected lcd_str to stdout you can then use:
puts("hello"); printf("pi is roughly %f", M_PI);
but all these need a single character outputting routine at their core. lcd_putchar (with the correct interface) is it. lcd_puts is not.
Earlier discussions glossed over the 'correct' putchar() function.
I would also suggest that you choose a more intuitive name for the FILE stream :
FILE lcd_stream = FDEV_SETUP_STREAM(lcd_putchar, NULL, _FDEV_SETUP_WRITE);
I look at "lcd_str" and immediately think "string".
I know that machines don't care what you call variables.
However c, ch, key, letter, ... imply a char or int
And s, str, buf, string, ... imply a pointer or array
I don't mind single letters for local variables. You can see all the references in the block. Hopefully the whole block fits on the screen.
Global variables need to be very descriptive or else you lose the plot. Only ASM programmers can keep 1000 global variables in their head at any one time.
Me too but this is what stdiodemo.c in the AVR-LibC manual has:
After looking at the above examples, I pulled a chunk of code out of a working experiment and inserted it into the current experiment that your comments above reference to:
#include#include #include #include #include #include "lcd.h" #define MYUBRR (((F_CPU / (9600 * 16UL)))-1) int uart_putchar(char c, FILE * fp) { while (!(UCSR0A & (1<<UDRE0))); UDR0 = c; return c; } void avrinit(void) { DDRA = 0xFF; //porta all outputs for LCD PORTB = 0xFF; static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE); stdin = stdout = &mystdout; UBRR0H = MYUBRR >> 8; UBRR0L = MYUBRR; UCSR0B = (1<<TXEN0)|(1<<RXEN0); UCSR0C = (1<<UCSZ01)|(1<<UCSZ00); // Set frame: 8data, 1 stp } int main(void) { avrinit(); lcd_init(LCD_DISP_ON_CURSOR_BLINK); while(1) { if(bit_is_set(PINB,0)) { lcd_clrscr(); /* put string to display (line 1) with linefeed */ lcd_puts("LCD Test Line 1\n"); printf("LCD Test Line 1\n"); /* cursor is now on second line, write second line */ lcd_puts("Line 2"); printf("Line 2"); while(bit_is_set(PINB,0)) { } } if(bit_is_clear(PINB,0)) {lcd_clrscr(); lcd_puts("AVRfreaks"); while(bit_is_clear(PINB,0)) { } } } }
I figured I would add the uart sending out a quick message, but while I get no compile errors my disassembly window says otherwise as I get nothing on the terminal program.
One thing I notice in the different notes of this:
Is that sometimes I see STREAM in place of fp:
int uart_putchar(char c, FILE * stream) { while (!(UCSR0A & (1<<UDRE0))); UDR0 = c; return c; }
tried both and get the same result. Will play with this for a little while.
Does not matter what you use. It's "just" a parameter/variable name. Add that it is actually not used and it matters even less.
Why not used, you ask? Search out the sketch for a tutorial that I wrote the other day and the answer is there.
You should take some time to fix your indentation. It is not a thing one does as the last step, so that the end result looks pretty. It is something you maintain all the time so that you have a better chance reading the code you yourself write.
1. Is your F_CPU defined correctly?
2. Can you see anything on the TX pin with a scope?
3. Do not do this:
Since your call to FDEV_SETUP_STREAM has NULL as the second parameter the stream can not accept input. Therefore you should not assign stdin. Not that it will make much damage here and now, but it is confusing and is a possible future malign bug. Just do
stdout = &mystdout;
Another thought:
If you tear out everything in the main() function (execept the initializations) and replace it with e.g. this:
uart_putchar( 'A', NULL); uart_putchar( 'V', NULL); uart_putchar( 'R', NULL);
Will that output anything on the UART? If 'no', then your problem is not with the streams/printf implementation but with the UART setup and/or communication as such.
Hmmm. On a train right now. Will look at your ideas later tonight
Thanks Johan
Since your program 'looks' ok to me, I thought that I would build it on a UNO.
I had to comment out the DDRA line. It is pointless anyway. The LCD port lines are initialised in the lcd_init() function.
I built and ran the program:
It displayed on both the LCD and UART.
If you have a problem with the UART, you are probably using a wrong F_CPU. I suggest that you set it in Toolchain->Symbols and make sure it agrees with the STK600.
Found the problem. Damned carfarcolus switch. It gets a little 'iffy' sometimes. Reset the jumper and things are working correctly.
In the meantime. I will read Johans excellent posts along with Cliffs and the others a few more times while I put together an exercise that will use what I have learned so far.
Thanks all.
Do not do this:
Just as a general point don't do it anyway.
stdin = &mystdout; stdout = &mystdout;
would have been clearer to the reader and won't generate any more code. But, as Johan says, if there is no input stream don't do the stdin= line anyway.
Before I head out this morning I am going to print out this threD for some light reading
Hi guys!
Recently I extended my little knowledge about MCUs on PICs and I find that the trend is to remove, deleting options ecc in function like sscanf() or similar (only one compiler support, badly, the sscanf, at latest versions of all compilers). But the printf() has a good support everywhere.
So I'm wondering if it is true that in a professional like environments, functions like sscanf() are never used? I mean, if I need to read a float number incoming from a string which contains also letters, is a good practice to make your own function? (is well known the overhead due to the sscanf() )
Any standard compliant C compiler must implement sscanf(). If it doesn't it is not a standards compliant C compiler. Whether the end users choose to use that or any other function is irrelevant. It sounds like slopiness/laziness if compilers (or rather their libc's) are being produced without one or more of the functions specified in the C standard.
It may well be true that not everyone would choose to use that function but without it examine your comment:
If there isn't a library function to that then how are you going to implement it exactly? I suppose you might just use atof() but it's going to involve more work on your part and you'll end up reimplementing parts of sscanf() anyway and likely with some bugs you add. The one argument against printf/scanf in 1/2/4K micros is, I guess, do you really want to spend 2-3K on one library function. If that is the issue then, yes, I guess you need to implement just small, targetted parts of the scanf functionality using your own implementation (though likely assisted by lesser library functions like atof()).
I'll add this: If the string input that is to be converted to a float has limitations on how it can be formatted (e.g. the counterpart producing the string is not a human but a computer program that keeps within tight limits regarding the format of the string) then you might be able to implement something that is more efficient than sscanf. It is still highly likely that atof() will be a better option than writing your own conversion proper.
I'll add that IME in a dozen years of AVR programming and scores of production applications, I've yet to use the scanf() family in an AVR app. [I've rarely used floating point either, but that is probably a different topic.]
It isn't the overhead of scanf() per se, but rather my aversion to having to process a free-form string on an AVR8 MICROcontroller. With some kind of fixed format, the detection of a valid "message" format at least becomes manageable. The error detection and recovery in a true free-form message can IMO become onerous.
