INT 0 trigger an interrup on level change?
11 posts / 0 new
I'm doing a stepper controler driven by the parallel port, but I've a problem, INT0 is triggered at any logical change, (as I known it is not posible), and I only want to trigger an interrupt on raising level.
I've configured ISC00.1 with the correct values from the datasheet
Any idea??
Regards
What is the correct value? Can you post some code?
/* John Butera */
This are the values i'm using:
1 1 The rising edge of INTn generates asynchronously an interrupt request.
sbi(EICRA, ISC00);
sbi(EICRA, ISC01);
Rey
Perhaps I need an externall pull-up resistor
Wy not, a little sample from encoder.c of AvrLib (not mine)
// File Name : 'encoder.c'
// Title : Quadrature Encoder reader/driver
// Author : Pascal Stang - Copyright (C) 2003
// configure interrupts for rising-edge triggering
sbi(ENC3_ICR, ENC3_ISCX0);
sbi(ENC3_ICR, ENC3_ISCX1);
// enable interrupts
ENC3_ICR Is #define ENC3_ICR EICRB,
And I don't want anybody to look at the datasheet, I've do it after, and as I say there is no way to produce a "on level change" interrupt on INT0,
For this reason I'm asking here...
You still have not said >>which<< AVR you are referring to. And we don't know what sbi() does--is it smart enough to know whether the address is too high for the SBI instruction, and do the port mod with masks?
And every AVR that I am familiar with can trigger INT0 on rising edge, falling edge, both edges, or low-level.
Lee
In my mind, "both edges" is equivalent to "level change".
Lee
Sorry for the abstraction, sometimes I forget some basics things,
target: atmega128,
compiler: avrgcc
I'm configuring INT0:
The External Interrupts 3 - 0 are activated by the external pins INT3:0 if the SREG I-flag
and the corresponding interrupt mask in the EIMSK is set.
:: Configuration:
ISCn1 ISCn0 Description
0 0 The low level of INTn generates an interrupt request.
0 1 Reserved
1 0 The falling edge of INTn generates asynchronously an interrupt request.
1 1 The rising edge of INTn generates asynchronously an interrupt request. * I'm using Using THIS ONE
SteveN, To many coffe for one day, friend, thank's anybody for the help
An example in assembler (I could do it in C but I prefer to do Copy & Paste):
INTERRUPT ACTIVATION:
in      r16,EIMSK
ori     r16,0x01
out    EIMSK,r16
INT0 -> RISING EDGE:
lds     r16,EICRA
ori     r16,0x03
sts     EICRA,r16
If you have global interrupts enabled (SEI), this should be enough...
Are you sure you're really seeing an interrupt on either edge? What's connected to the external interrupt input? Could you be getting contact bounce?
Note also that the 01 combination is reserved in EICRA (external interrupts 3-0). In EICRB (external interrupts 7-4), the 01 combination selects "any logical change on INTn generates an interrupt request" (i.e., both edges will generate an interrupt).
Note that sbi( ) is depreciated. You should use instead, for example:
EICRA |= ( 1 << ISC01 ) | ( 1 << ISC00 );
Don
A data pin of a PC parallel port, I change it by a pc program from 1 to 0 and from 0 to 1, and follow the signal with the scope,
Not, because the interrupt drive a steep in a stepper motor and it do his steep normaly,
Yes, this is the first I think, but i'm configuring 11
>>Code:
I Know, but i've a hard head,
Thank's for all
