xmega-256A3BU and programming it
2 posts / 0 new
So i got my xmega-256A3BU with bootloader. But now the problem im having is when i use FLIP to program it, it just says AtLibUsbDfu.dll is not found even its there already. My board can connect to PC using USB connector.
Its using AVR based so i can program it using Arduino(TM).
Any idea how to make it compatible ?
Programming my board using Arduino(TM) ?
Any help is apreciated.
I had a similarly cryptic message when I switched computers. Did you check that your device shows up as Atmel DFU device(no warning or unknown signs) in your device manager if you are using Windows? It requires a DFU USB driver.
