PROGMEM issue with avr-gcc 4.6.2
6 posts / 0 new
This used to work fine with avr-gcc 4.3.3, but now I get
error: variable 'all_tables' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
#include
#include
const uint16_t table0[] PROGMEM = {0,1,2};
const uint16_t table1[] PROGMEM = {0,1,2};
const uint16_t* all_tables[] PROGMEM = {table0, table1};
int main()
  return 1;
Almost everything has been asked and discussed before. You could have had the answer directly if you had used the forum search function, had entered "must be const in order to be put into read-only section" and ticked "Search for all terms".
The fifth hit for this search is https://www.avrfreaks.net/index.p... where I believe you will find the solution to your problem.
Thanks for taking the time to help. I was trying to search for it in the forum, but not doing a good job of it I see.
To be fair, the search facility on the site is a bit weak. The quick-search field in the left-hand margin is especially poor.
It's not obvious, but the better search option is the 'search forum' button at the top of each forum page. Follow @JohanEkdahl's advice on how to use it.
Alternately, and often better, is a google search with site:www.avrfreaks.net tacked onto the end.
JJ
You can read the GCC release notes:
    "On AVR, variables with the progmem attribute to locate data in flash memory must be qualified as const."
In your case the object is all_tables. Just add a const to it.
So write
const uint16_t* const all_tables[] PROGMEM = {table0, table1};
with `const` twice.
