how can i check the ICE200? please advise
3 posts / 0 new
Hi Freaks.
Is there a way to verify and check the ICE 200
to see if it works fine?
this are the massages that ikeep on getting
Loaded plugin STK500
Loaded partfile: C:\Program Files\Atmel\AVR Tools\PartDescriptionFiles\AT90S8515
ICE200 partChanged() Couldn't get part description! (8002801D)
ICE200 ICE200 Configured...
Loaded partfile: AT90S8515
Error loading objectfile speak & spell.cof
I would get rid of the & in the file name, just in case it causes prolems. Also there is a bug with Studio 4.xx (at least on my machine, Atmel cannot duplicate the problem) and the ICE. Stupid questions time :) Do you have your target board powered? What are you using for a target (stk500??) Perhaps you could start with a simple led flashing program to make sure that the target and the ICE are working ok. Also may want to try with Studio 3.56 as this is the recommended tool for the ICE200.
Hi JS
Thank you for your replay
The whole systems worked fine for about two years with the same setup
The file name which includes the "&" worked fine until yesterday.
I am using the STK500 with the ICE200.
I usually had used the AVRStudio 4.xx and it worked fine but after this problem appeared i tried to load the latest version of the AVRStudio and it still didnt fix it.
So i went back to the original version and i am still having this problem.
I tried to load one of the examples that comes with the CodeVision and i still get the same masssages and right after that i keep on getting the masssage of windos that asking me if i want to sent error report to microsoft.
I was looking in Google for this number ( 8002801D ) and i found out that there is something thjat might be due to a regestry problem
But i am not sure........
The only thing that i loaded last week was the new version of Norton Antivirus but even when i tried to uninstall it ....the same thing happen.
Please try to see if you understand what microsoft wants me to do if you can go through that i would appriciate it.
And one more thing if i may......Where can i download the AVRStudio 3.56
Thank you very much
