AVR Dragon -> ATtiny167 (3v3 power-rail)
3 posts / 0 new
I've accidentally connect the 167 over to the 3v3 power-rail while having the programming cables connected to AVR Dragon's ISP socket. I've switched back to the 5v but still getting "Unable to enter programming mode...". Have I burnt the SCL/MISO/MOSI pins?
However, the chip is still performing the blinking of the LED on PORTA0 as in my test code. Is there anyway to salvage this chip?
Thanks.
Once an engineer, forever an engineer
Have you unplugged everything and started from the beginning? ie unplug Dragon, restart Studio, power down the target.
Yeap, sure did. Did 3 times & results were the same. I have a spare ATtiny167 & tested on the AVR Dragon & it was good.
I scoped the MOSI pin & it seems I had fried it?
Top Pix of Bad ATtiny167
Bottom Pix of Good ATtiny167
:? No idea. Probably I'll need a voltage level translator if I do that again...
