Software Reset on mega128
7 posts / 0 new
I have a mega128 (in an ethernut) and are looking for ways of having a software-only method of resetting the processor. Has anbody tried a software-generated reset not using the watchdog or hardware?
The only true reset will be a watchdog or pulling the reset pin low. What is wrong with using the watchdog?
But if you want a semi-reset in software, jump to address 0. This won't re-initilize the hardware though...
-Colin
I was hoping there was a way of getting the reset through a software-called interrupt (like the HC12 "swi"), which the mega128 doesn't have (or at least I didn't find it in the instruction set). In this case, the you're probably right - running the watchdog and allowing it to time out is the best way of getting a software-generated reset.
I was hoping to avoid plugging the watchdog because I'm having to use the Nut/OS that comes with the Ethernut, and that means a new task thread in the OS to ensure proper timing, and my available memory isn't going to take too many more threads...
Thanks for the response!
Why would you need another thread to let the watchdog timeout? To issue a software reset via the watchdog timer, you simply sit in a tight loop after enabling the watchdog timer (if it was not already enabled). Disabling interrupts before the loop would ensure that no other code gets executed while you wait for reset.
/* John Butera */
You need a place to reset the watchdog on a regular basis isn'it?
In the case of NutOs this place may be the main thread, another
special thread or in every other threads.
Cosmin
Oh I see, pepsi's method is to enable->enter loop->reset, not
enabling the watchdog somwhere at program start.
this is what i use on AVR GCC :
u will have to include avr/wdt.h
wdt_enable(0); //enabling wdt with shortest time out
delay(200); // a loop...u can use a while(1); also
hope it helped..
good luck
Shadab
Exactly.
Even that is overkill. Just do (with AVR GCC):
#include
wdt_enable(0);
// Sit in infinite loop until proccessor resets.
for(;;)
You can even make a macro out of the thing:
#include
#define software_reset()  \
do{  \
    wdt_enable(0); \
    for(;;){} \
} while(0)
void task(void)
    software_reset();
