Not able to read key press from 4X4 HEX keypad
12 posts / 0 new
I'm new to AVR,I'm trying this code but its not working,I'm not able to read the keypress,Here there is code for only first row scanning... Pls guide me....
#include
#include
#include
#define ROW1	PINC0	// pin1
#define ROW2	PINC1	// pin2
#define ROW3	PINC2	// pin3
#define ROW4	PINC3	// pin4
#define COL1	PIND0	// pin1
#define COL2	PIND1	// pin2
#define COL3	PIND2	// pin3
#define COL4	PIND3	// pin4
	DDRA=0xFF; // Making PORTA as output Port (DATA)
	DDRB=0x07; // Making PORTB as output (CONTROL)
        LCD_init(); // LCD Intialization
	LCD_goto(1,1); // To choose from which line and character the string has to be displayed
	LCD_print("THE PRESSED KEY:"); // String which has to be displayed on LCD
	MCUCSR=(1<<JTD);    // DISABLING JTAG
        MCUCSR=(1<<JTD);
        DDRC=0x00;
        DDRD=0xFF;
	PORTC=0x00;		//MAKING PORTC AS INPUT
	PORTD=0xFF;		//MAKING PORTD AS OUTPUT
        PORTD = PORTD & 0x7F;     // link column 1 to GND (PORTB0 = 0)
        asm volatile ("nop");
        while(COL1==0)              //CHECK IN 1sT COLOUMN
	 if (ROW1==1)               //CHECK IF ANY KEY IN ROW 1 IS PRESSED
           LCD_goto(2,7);
           LCD_print("0");
           break;
         else if (ROW2==1)         //CHECK IF ANY KEY IN ROW 2 IS PRESSED
            LCD_goto(2,7);
            LCD_print("1");
	    break;
         else if (ROW3==1)         //CHECK IF ANY KEY IN ROW 3 IS PRESSED
            LCD_goto(2,7);
	    LCD_print("2");
	    break;
         else if (ROW4==1)         //CHECK IF ANY KEY IN ROW 4 IS PRESSED
            LCD_goto(2,7);
            LCD_print("3");
	    break;
[capitals removed from thread title and CODE tags added. Please use normal case for thread titles in future and add your own CODE tags around sequences of code - moderator]
You're not reading the pin register for port C or D. PINC0 has the value of 0, C1=1 and so on. Youmneed to do something like this:
If ( PINC & (1<<PINC0))
But i've globally defined PINC0 as ROW1 and PIND0 as COL1 and so on...
What Kartman is saying, Praveen, is that PINC0 is defined to be a bit number rather than a bit mask.
Although, as you say, you have defined "ROW1" as PINC0, you are still referring to bit numbers.
What you need is something like...
if (PINC & (1 << ROW1))
As this converts the bit number (0) into a mask (0x01).
I hope that helps.
/A
If we are not supposed to eat animals, why are they made out of meat?
Oh oh... Got it... Thanks AndyG... I changed the code as below
while(PIND & (0 << COL1))              //CHECK IN 1sT COLOUMN
	 if  (PINC & (1 << ROW1))              //CHECK IF ANY KEY IN ROW 1 IS PRESSED
           LCD_goto(2,7);
		   LCD_print("0");
		   break;
      else if (PINC & (1 << ROW2))       //CHECK IF ANY KEY IN ROW 2 IS PRESSED
            LCD_goto(2,7);
		    LCD_print("4");
			break;
      else if (PINC & (1 << ROW3))         //CHECK IF ANY KEY IN ROW 3 IS PRESSED
            LCD_goto(2,7);
		    LCD_print("8");
			break;
       else if (PINC & (1 << ROW4))         //CHECK IF ANY KEY IN ROW 4 IS PRESSED
            LCD_goto(2,7);
		    LCD_print("C");
			break;
But when i press the key,the LCD is just blinking... Not getting the display on LCD
This line does not make sense, Praveen. The "while" loop will never execute.
/A
You need to clear column 1 and set all other columns. This code does not do this.
Use
PORTD |= 0x0f; // set all columns
PORTD &= ~(1<<COL1); // clear COL1
And you should test for 0, not for 1.
if ((PINC&(1<<ROW1))==0) //CHECK IF ANY KEY IN ROW 1 IS PRESSED
Try this
#include
#include
#include
#define setbit(port,bit)  ((port) |=  (1<<bit)) // set bit
#define clrbit(port,bit)  ((port) &= ~(1<<bit)) // clear bit
#define COL1 PD0 // pin1
#define COL2 PD1 // pin2
#define COL3 PD2 // pin3
#define COL4 PD3 // pin4
   DDRD=0xFF;
   DDRC=0x00;
   PORTC |= 0x0f; // pull-up on input pins
   MCUCSR=(1<<JTD);
   while(1)  // main loop
      // FIRST COLUMN
      PORTD = PORTD & 0x0F; // set all columns to 1
      clrbit(PORTD,COL1);   // link column 1 to GND (PORTB.0 = 0)
      while (bit_is_clear(PIND,COL1)) //CHECK IN 1sT COLOUMN
         _delay_ms(50);  // debounce
         if (bit_is_clear(PINC,ROW1)) //CHECK IF ANY KEY IN ROW 1 IS PRESSED
            LCD_goto(2,7);
            LCD_print("0");
            break;
         if (bit_is_clear(PINC,ROW2)) //CHECK IF ANY KEY IN ROW 2 IS PRESSED
            LCD_goto(2,7);
            LCD_print("1");
            break;
         // test ROW 3,4
         loop_until_bit_is_set(PIND,COL1); // wait for buton released
      // SECOND COLUMN
      PORTD = PORTD & 0x0f; // set all columns to 1
      clrbit(PORTD,COL2);   // link column 2 to GND (PORTB.1 = 0)
      while (bit_is_clear(PIND,COL2)) //CHECK IN 2nd COLOUMN
   } //while(1)
} //main()
Thank u Visovian... U made me understand how it acually works... The program worked...
I've edited thread title and code tags above. Please see my note in the first post. [Moderator]
Now I have noted a mistake.
Put this line on the end of while(1) loop (after all columns checked).
Probably a good idea (for future readers) for you to edit your code to include this. Less confusion/mistakes.
Cheers,
Ross
Ross McKenzie, Melbourne Australia
