[LW Mesh] Frequency problem
5 posts / 0 new
Hi !
I'm using ATZB-A24-UFLR module with LW Mesh.
My main looks like this:
	SYS_Init();
	HAL_UartInit(38400);
	while (1)
		SYS_TaskHandler();
	 	HAL_UartTaskHandler();
		APP_TaskHandler();
My UART works OK with 4800bps with HyperTerminal but not with 38400 as defined in main().
And also my timers are 8 times "faster". I blik LED with timer of 125 ms to get blinks of 1 second.
Looks like my frequncy is devided or multiplied by 8. ATZB-A24-UFLR module has frequency of 8 MHz I think.
I also run BitCloud on this module and everything's OK. (UART and timers)
What do I have to change in app?
Thaks and regards !
Hi xtal_88,
It seems that you haven't a correct fuse settings. If my memory doesn't fail me, fuse settings are different for BitCloud and Lightweight Mesh.
Rober
You need to disable CKDIV8 fuse.
Thank you for quick responses guys!
I remember that I had some problems with fuse bytes/bits.
I disabled JTAGEN or some other bit(s) on few modules and couldn't flash them any more.
If I understand what you are saying :
if I use BitCloud, CKDIV8 must be enabled ?
and
if I use LW Mesh, CKDIV8 must be disabled ?
Once I disable CKDIV8, can I set it again without any problems ?
Thank you once more !
Yes, you can. Furthermore, you can disable it in the software:
CLKPR = (1 << CLKPCE);
CLKPR = 0;
