Codevisionavr EEPROM>>>>>>>>>>
6 posts / 0 new
hi guys i have a problem with writing/reading eeprom on atmega32a. i need to add some pin numbers to eeprom and read them. this is a password lock sysytem.
the problem is how can i add new pin number like a second one or a third one??????
without deleting the existing pins
pin1=1234
pin2=1567
4 (decimal) digit PINs range from 0 through 9999, easily stored in a 16 bit word.
There is therefore room for 512 PINs in the '32s EEPROM.
Reading an erased EEPROM word will return the value 0xffff (65535), which is not a valid PIN.
To STORE a new PIN, scan the EEPROM address space for a word value 0xffff, and store the new PIN there.
To VERIFY a PIN, scan the EEPROM address space... if you don't find a word with that value, refuse access to the user.
To DELETE a PIN, locate it and write 0xffff to that location.
Whenever you find yourself using variable names like pin1, pin2 the chances are you want to use an array pin[] and hence pin[1], pin[2] and so on.
I believe the OP was talking about Personal Identification Numbers. I don't use CodeVision, but IIRC you can do something like...
eeprom unsigned int PIN[10];
to reserve storage for 10 PINs.
Then, to store a new PIN in the next available (erased) slot
bool store_pin(unsigned int pin)
    int i;
    for( i = 0; i < 10; i++){
        if( PIN[i] == 0xffff){
            PIN[i] = pin;
            return true;
    return false;
thanks for that
but i have another question i think codevision avr wraps eeprom but i could not find the codes to access the eeprom. and the codes to scan and store.
You could always give in and read the CodeVision manual ;-)
That will tell you that it has an "eeprom" modifier for variable declaration and the read/write access is implicit.
