Atmel Studio 6 and 6.1 freezes after a few seconds, Win8 x64
12 posts / 0 new
Hi guys,
After I run Atmel Studio (both 6 or the newest 6.1) the program starts, the screen looks OK. Then, after a few seconds the program freezes. After that I get a Windows report that the program stopped working.
I am running Windows 8 Pro, on an X64 system. I've tried everything I could think of, installed, reinstalled and even gone back to an older version, but nothing helped.
I've searched the net, tried some fixes for various versions, but nothing.
Please advise.
Thank you,
David
It should be noted that it worked until recently.
With the ugly Win8? :-)
Do you happen to be using USB>RS232 adaptors on your system? AS was crashing (still crashes) with a Prolific adaptor and a terminal program for me.
In defense of studio; most programs using .net4 or newer can crash when using Prolific... I'm not saying, but just observing...
:: Morten
Correct, I wasn't quite blaming Studio...for once... :wink:
Hi John,
Nope, I've disconnected everything from the notebook.
Any advice would be greatly appreciated. I'm kind of desperate.
edit: I just learned that another release has been released today, I'll try that.
If it crashes, you should have the option to get a detailed report of the crash or even better send the error report (yes they do actually get to us eventually).
Also check the event log for things that may have been logged in the crash. Even also, what sort of exception box? JIT Debug or just the normal Windows oooops box?
:: Morten
Hi meolsen,
The message is a classic Windows ooops message - Atmel Studio stopped working. The following data is in the message:
Description
Faulting Application Path:	C:\Program Files (x86)\Atmel\Atmel Studio 6.1\atmelstudio.exe
Problem signature
Problem Event Name:	APPCRASH
Application Name:	atmelstudio.exe
Application Version:	6.1.0.0
Application Timestamp:	516fbf54
Fault Module Name:	KERNELBASE.dll
Fault Module Version:	6.2.9200.16451
Fault Module Timestamp:	50988950
Exception Code:	e0434352
Exception Offset:	00014b32
OS Version:	6.2.9200.2.0.0.256.48
Locale ID:	1033
Additional Information 1:	5861
Additional Information 2:	5861822e1919d7c014bbb064c64908b2
Additional Information 3:	f3d5
Additional Information 4:	f3d5be0cad2787556264647dc02181c3
Extra information about the problem
Bucket ID:	586a986a49b63ea81e9f6a545757b90e (-736254658)
I have sent the reports as requested.
Where is the event log you mentioned located?
David
Ouch... Kernelbase :P
Try opening a command line in the studio install dir and invoke studio with atmelstudio.exe /SafeMode
If that does not work, I need to know if this only happens with 1 project or generally (e.g does it freeze if you open studio by opening a project/solution, or if the crash occurs just by launching studio and letting it stand idle at the start page.
If it crashes on a certain project, the I propose to trash the project files and recreate them. The problem would most probably stem from some stray character somewhere in the project files that chokes the parsers.
If it happens when ideling, then the problem is a bit more iffy. Probably some strong signed dll somewhere on your system that should have been updated but is locked and therefore is not in the correct version. Usually to solve this I would make you uninstall all applicable programs below (note that other things might get nuked in the process, so backups of projects etc might be usefull):
  • Atmel Studio, all version
  • Visual Studio, Normal and Express versions
  • MSSQL
  • All references to Visual Studio/Isolated Shell etc
  • All references to .net4 or greater
  • Clean registry node at HKEY_CURRENT_USER\Software\Atmel\AtmelStudio\6.0
  • Clean registry node at HKEY_CURRENT_USER\Software\Atmel\AtmelStudio\6.0_Config
Phew. Beware that the registry nodes I mention is from memory, so they may be somewhere else :P
Then, download the newly released 6.1 Full installer (yes, the big one) and install.
:: Morten
I'm having the same problem!
Recently I uninstalled Atmel Studio 6, and then installed Atmel Studio 6.1. Anytime I open Studio, the program will eventually get to the start page, then freeze. It will then proceed to go into the "not responding" state, and then freeze my computer. I uninstalled and reinstalled a few times, and still the same result.
Avatar maliciously stolen from xkcd.com.
Just reverted back to 6.0, and no freezing.
