ADC and CDC working togheter.
3 posts / 0 new
I have a problem with cdc and adc working togheter. I used adc and cda exaples from Atmel Studio 6(ASF). I'm using at32uc3a Xplained kit. This is my code:
#include
#include
#include
#include
#include
int value=0;
int main (void)
	AVR32_ADC.mr |= 0x1 << AVR32_ADC_MR_PRESCAL_OFFSET;
	adc_configure(&AVR32_ADC);
	adc_enable(&AVR32_ADC, 1);
	sysclk_init();
	board_init();
	irq_initialize_vectors();
	cpu_irq_enable();
	stdio_usb_init();
	while (true) {
		delay_ms(100);
adc_start(&AVR32_ADC);
value = adc_get_value(&AVR32_ADC,1);
			printf("value:, &d   ",value); // echo to output
I have problem with adc_get_value(&AVR32_ADC,1) function, debugger don't show changes in sr register, problem dosen't exist if i don't use sysclk_init() function, but this is nessesary for using cdc.
Please help.
You need to configure the clocks correctly. Comment out the lines for the Peripheral Clock Management Options (as indicated below) in the conf_clock.h file in the USB CDC example code when combining with the ADC conf_clock.h file.
// ===== Peripheral Clock Management Options
//#define CONFIG_SYSCLK_INIT_CPUMASK   (0)
//#define CONFIG_SYSCLK_INIT_PBAMASK   (0)
//#define CONFIG_SYSCLK_INIT_PBBMASK   (0)
//#define CONFIG_SYSCLK_INIT_HSBMASK   (0)
Solved. I used
sysclk_enable_pba_module(SYSCLK_ADC);
next to sysclk_init() function.
edit:
I have next problem. In this case i wanna use timer and usb cdc togheter. This is my code:
#define EXAMPLE_TC                 (&AVR32_TC0)
//! \note TC Channel 0 is used.
#define EXAMPLE_TC_CHANNEL         0
//! \note IRQ0 line of TC0 module channel 0 is used.
#define EXAMPLE_TC_IRQ             AVR32_TC0_IRQ0
//! \note IRQ Group of TC0 module
#define EXAMPLE_TC_IRQ_GROUP       AVR32_TC0_IRQ_GROUP
//! \note Interrupt priority 0 is used for TC in this example.
#define EXAMPLE_TC_IRQ_PRIORITY    AVR32_INTC_INT0
#if defined (__GNUC__)
__attribute__((__interrupt__))
#elif defined (__ICCAVR32__)
#pragma handler = EXAMPLE_TC_IRQ_GROUP, 1
__interrupt
#endif
static void tc_irq(void)
 * \brief TC Initialization
 * Initializes and start the TC module with the following:
 * - Counter in Up mode with automatic reset on RC compare match.
 * - fPBA/8 is used as clock source for TC
 * - Enables RC compare match interrupt
 * \param tc Base address of the TC module
static void tc_init(volatile avr32_tc_t *tc)
	// Options for waveform generation.
	static const tc_waveform_opt_t waveform_opt = {
		// Channel selection.
		.channel  = EXAMPLE_TC_CHANNEL,
		// Software trigger effect on TIOB.
		.bswtrg   = TC_EVT_EFFECT_NOOP,
		// External event effect on TIOB.
		.beevt    = TC_EVT_EFFECT_NOOP,
		// RC compare effect on TIOB.
		.bcpc     = TC_EVT_EFFECT_NOOP,
		// RB compare effect on TIOB.
		.bcpb     = TC_EVT_EFFECT_NOOP,
		// Software trigger effect on TIOA.
		.aswtrg   = TC_EVT_EFFECT_NOOP,
		// External event effect on TIOA.
		.aeevt    = TC_EVT_EFFECT_NOOP,
		// RC compare effect on TIOA.
		.acpc     = TC_EVT_EFFECT_NOOP,
		 * RA compare effect on TIOA.
		 * (other possibilities are none, set and clear).
		.acpa     = TC_EVT_EFFECT_NOOP,
		 * Waveform selection: Up mode with automatic trigger(reset)
		 * on RC compare.
		.wavsel   = TC_WAVEFORM_SEL_UP_MODE_RC_TRIGGER,
		// External event trigger enable.
		.enetrg   = false,
		// External event selection.
		.eevt     = 0,
		// External event edge selection.
		.eevtedg  = TC_SEL_NO_EDGE,
		// Counter disable when RC compare.
		.cpcdis   = false,
		// Counter clock stopped with RC compare.
		.cpcstop  = false,
		// Burst signal selection.
		.burst    = false,
		// Clock inversion.
		.clki     = false,
		// Internal source clock 3, connected to fPBA / 8.
		.tcclks   = TC_CLOCK_SOURCE_TC3
	// Options for enabling TC interrupts
	static const tc_interrupt_t tc_interrupt = {
		.etrgs = 0,
		.ldrbs = 0,
		.ldras = 0,
		.cpcs  = 1, // Enable interrupt on RC compare alone
		.cpbs  = 0,
		.cpas  = 0,
		.lovrs = 0,
		.covfs = 0
	// Initialize the timer/counter.
	tc_init_waveform(tc, &waveform_opt);
	 * Set the compare triggers.
	 * We configure it to count every 1 milliseconds.
	 * We want: (1 / (fPBA / 8)) * RC = 1 ms, hence RC = (fPBA / 8) / 1000
	 * to get an interrupt every 10 ms.
	tc_write_rc(tc, EXAMPLE_TC_CHANNEL, (sysclk_get_pba_hz() / 8 / 1000));
	// configure the timer interrupt
	tc_configure_interrupts(tc, EXAMPLE_TC_CHANNEL, &tc_interrupt);
	// Start the timer/counter.
	//tc_start(tc, EXAMPLE_TC_CHANNEL);
	tc->channel[0].ccr=1<<2|1<<0;
int ch=12345;
int main (void)
	volatile avr32_tc_t *tc = EXAMPLE_TC;
	/* Initialize basic board support features.
	 * - Initialize system clock sources according to device-specific
	 *   configuration parameters supplied in a conf_clock.h file.
	 * - Set up GPIO and board-specific features using additional configuration
	 *   parameters, if any, specified in a conf_board.h file.
		//TC
	sysclk_init();
	//sysclk_enable_peripheral_clock(EXAMPLE_TC);
	AVR32_PM.pbamask|=1<<16;
	cpu_irq_disable();
	INTC_init_interrupts();
	// Register the RTC interrupt handler to the interrupt controller.
	INTC_register_interrupt(&tc_irq, EXAMPLE_TC_IRQ, EXAMPLE_TC_IRQ_PRIORITY);
	// Enable the interrupts
	cpu_irq_enable();
	cpu_irq_enable();
	stdio_usb_init();
	tc_init(tc);
	board_init();
	/* Enable the ADC channels. */
	while (true)
			printf("d",ch); // echo to output
If i comment tc->channel[0].ccr=1<<2|1<<0; (tc_start) function i can connect with USB, if i non-comment that finction my computer cant recognise my uC, i dont know why that happen...
