ADC bug? This may be silly
3 posts / 0 new
If this is a dumb error on my part, I apologize. I am varying the voltage to an pinput pin (PORT C bit 0) and when the ADC reads 0xff I light an LED. Big deal! Should work right?
It is very unreliable. Sometimes it works, sometimes it does not. Mostly the LED is ON and I cannot get it go off. Hmmm..... Can anyone spot the bug? I surely wish I could see it.
unsigned char read_adc(unsigned char adc_input)
ADMUX=adc_input|ADC_VREF_TYPE;
ADCSRA|=0x40; // Start the AD conversion
while ((ADCSRA & 0x10)==0); // Wait for the AD conversion to complete
ADCSRA|=0x10;
return ADCH;
void main(void)
unsigned char i;
InitHardware(); //Init IO ports
for(;;)
i=read_adc(PINC.0); //ADC input PORTC pin 0
if(i == 0xff)
PORTB =0xff;
PORTB=~0xff;
I don't quite understand this part :
You don't tell us the compiler you are using. But I think that PINC.0 is the digital value of pin 0 of the PORT C, which may value 0 or 1. If PC0 is analog channel 0, then you need to use :
i=read_adc(0);
Alejandro.
http://www.ocam.cl
Thank you!!!!!!!!
You are right. I was using PINC.0 which reads the "digital" value. I changed the code to i=read_adc(0); It works now. Thanks for saving me time.
