Can't access ABDAC on UC3-A3 Xplained Board
5 posts / 0 new
Hello
Im working on a UC3-A3 Xplained board.
The Chip on the Board is a AT32UC3A3256-U.
I use the AVR-Studio6, completly updated. ASF is at version 3.5.1.
For debugging I use a JTAGICE-mkII
When I try to access the ABDAC Peripherials, I can't get it to work.
My tests are based on another tread here in the Forum.
https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=84160
First of all, I included the ASF-Library for the ABDAC.
Then I initialize the board:
board_init();
sysclk_init();
irq_initialize_vectors();
cpu_irq_enable();
I configured SYSCLK_SRC_OSC0.
I initialize the Pin as followed:
gpio_enable_module_pin(AVR32_ABDAC_DATA_0_0_PIN, AVR32_ABDAC_DATA_0_0_FUNCTION);
Init the DAC Samplerate:
abdac_set_dac_hz(&AVR32_ABDAC, FOSC0, 48000);
Register the Interrupt to the INTC
Disable_global_interrupt();
INTC_register_interrupt(&abdac_int_handler, AVR32_ABDAC_IRQ, AVR32_INTC_INT0);
Enable_global_interrupt();
Activate the ABDAC Interrupt:
AVR32_ABDAC.ier = ABDAC_BIT(IER_TX_READY);
And finally activate the ABDAC:
abdac_enable(&AVR32_ABDAC);
Of course I also defined the Interrupt:
ISR(abdac_int_handler, AVR32_ABDAC_IRQ, AVR32_INTC_INT0)
	U16 sample;
	sample = ((U8)sound_data[i++]+0x80) << 8;
	AVR32_ABDAC.sdr = ABDAC_BF(SDR_CHANNEL0, sample) | ABDAC_BF(SDR_CHANNEL1, sample);
	if (i >= SAMPLE_COUNT) i = 0;
What happens:
The GPIO-Configuration seems to work.
My Scope shows, that the line is pulled down. At minimum, something happens :-)
The DAC-Samplerate is configured in the PM->gcctrl5... It seems to work. I see in the IO-View, that some flags were changed.
The Interrupt registering should be correct aswell.
And now comes the Problem:
When I ty to access any register of the ABDAC, nothing happens. I can't see any changes in the IO-View.
Neither the ABDAC-Enable nor the IER_TX_READY changes anything.
And of course, no ABDAC-Interrupt happens when I let the program run.
Other program-sections seem to work properly. As a example, the touch-slider and button work properly. (And yes, I also tried the ABDAC running without the qtouch things... doesn't works either)
Does someone know what the problem could be? I also looked for any hints, that the abdac is deactivated on my controller, like the audio codecs ,which are only active on a AT32UC3A3256-AU...
But I didn't found anything.
Thanx for any suggestions.
Martin
Well... Hello again
Meanwhile I tested a lot more, and I found the small but momentous bug.
It was a small snippet from the qtouch-code-example, which turned off essential clocks, which are used by the DAC.
And without this clocks the DAC couldn't be accessed.
In a nutshell:
The codesnippets in the first post work fine!
Martin
Hi
I am playing around with the UC3A3 Xplained dev board. How did you configure your clocks for the ABDAC bitstream? Sadly there is not example code for this dev board.
Thanks, ProfChaos
Hello ProfChaos
Well, generally it is absolutly easy.
You can use the functions abdac_set_dac_hz and abdac_set_dac_sample_rate. But they work not really good in my opinion. Especially because you dont really know what they do...
Therefore I programmed my Clockconfigs on my Own. And it works perfectly.
The two functions above by the way also only configure the PM registers as I do...
sysclk_enable_peripheral_clock(&AVR32_ABDAC);
pm->GCCTRL[ABDAC_GCLK].div= 6;  // div by 2*(6+1)=14
pm->GCCTRL[ABDAC_GCLK].diven=1; // Div Enable
pm->GCCTRL[ABDAC_GCLK].pllsel=1;// PLL source
pm->GCCTRL[ABDAC_GCLK].oscsel=0;// PLL 0
In my Case I overclocked my Oscillator a little bit to 72MHz.
As you can see in the Code, I use the PLL0, divide it by 14. After this, the additional BuiltIn Prescaler of 256 comes in.
72000000 / 14 / 256 = 20089.3Hz
According to the Datasheet you should run your Chip with 66MHz max. But 72MHz works fine :-)
I hope it helps a little.
Regards
Martin
Its working. Needed the LP filter from the application note. Thanks Martin for your help!!
