readProgramCounter failed [SOLVED]
8 posts / 0 new
I have tried write my the first program for Mega B1-Xplained board (xMega 128B1). Very simple program for LED blinking. When I try program chip - it is ok and program working.1 But when I tried debug program I have got message
"Failed to launch program
Error: The operation can not be performed with target MCU in its current state.
Debugger command readProgramCounter failed."
I have found any advices on AvrFreaks, but downgrade firmware on JtagICE or use Atmel Studio 4 - it is not for me.
I am using:
Atmel Studio 6
Atmel AVRATJtag ICE MK II
Win 8 - 64bit
There have been some issue with the JTAGMk2 an AS6 from what I have read here. They may be fixed in a newer version of Studio.
When you do "Start debug and Break" have you turned off the programming window if it was still open?
Did you select the JTAG ice Mk2 as the debugging tool for your project and selected the correct debug mode? (PDI or JTAG)
- Yes, when I "Start debug and Break" - programming windows is closed
- Debugging tool JTAG MK2 is select - and mode PDI.
- Programming working.
- I can use SW Simulator, but HW JTAG debug is better.
Please try the new 6.1 release. I believe that there were some firmware fixes that may help on this issue
:: Morten
OK - thanks - Upgrade to 6.1 - problem with error message was solved.
- Now another small question. When I click on "Start debugging and break", start "Steps my program" and look on "Processor window". I see Cycle counter, Frequency and Stop watch not working - no values. Is it OK ? I think this data should be good for me.I need to know exactly time info.
Those are only for the simulator aren't they?
Thanks to everybody,
Now - I can mark this post as [SOLVED]
Good to hear.
:: Morten
