General Purpose IO Pins
8 posts / 0 new
I need to put some universal IO pins on a unit. As they'll be connected to the real world they need some protection. Ideally I'd like them to work as...
1) open-collector outputs
2) digital inputs to detect an external DC voltage in the 5-24v range
3) digital inputs to detect switch closure to ground
Any thoughts?
My current doodle looks like this (ignore pin numbers)...
1) That should be an HC541.
2) R1 might need to be a bit lower to give a decent wetting current to any switch.
I'd avoid using a zener and go for something like a transil that is meant for tranient protection. NXP have some nifty transient protectors in a sow20 package. That part number escapes me at the moment but you get 18 units in one package - smt only though.
Any thoughts?
That looks like it will work as open-collector output and is able to detect switch closure to ground, as there is the pull-up.
But because of the pull-up, it cannot detect if it has +24 connected or disconnected, as nobody pulls low when it is disconnected.
Thanks Jepael,
not being able to detect if the 24v is disconnected isn't a requirement, only that it's 0v or 24v (actually 0v or 'more than 1/2VCCish').
http://www.nxp.com/products/auto... perhaps?
Or something like SN74S1053--lower TDP, but you get 16 series pairs instead of individual diodes, so it oughta be easier to route.
BZA100 it is!
