Lightweight Mesh error
3 posts / 0 new
Hi!
I've just started to "play" with Lightweight Mesh and I have problem building template application.
I use AVR Studio 5.1.208 on Windows 7 64-bit, new installation both.
I started:
C:\z_project\LwMesh_1_0_1\apps\Template\astudio\Rcb128rfa1_ATmega128rfa1.atsln
then got build error:
Error   1   The command "avr-objcopy -O ihex -R .eeprom Template.elf Template.hex
avr-objcopy -O binary -R .eeprom Template.elf Template.bin" exited with code 9009.   C:\Program Files (x86)\Atmel\AVR Studio 5.1\Vs\Avr.common.targets   27   5   Rcb128rfa1_ATmega128rfa1
Is something wrong with project properties?
Thank you !
Best Regards !
Almost all problems have been experienced by someone else before you. Chances are that they have been discussed already.
You need to trim your Google capabilities. Feed it with "avr-objcopy exited with code 9009" and you will get al least these:
...and likely several more.
No one is seriously still using the V5 bugfest at this stage are they? Suggest you upgrade to 6.0SP2 which was the first ever really stable version of AS5/6.
