This is not so bad ??
56 posts / 0 new
Pages
Just be aware of the dragons when you edit a system header file. :P It will/may/could be overwritten on upgrades
:: Morten
clawson wrote:
Anybody from Atmel following? what's the best way to inform the powers that be?
I'll move this thread to the AS6 forum. Someone ought to raise a Bugzilla entry but I'm sure someone from Atmel will read it in the AS6 forum and do that anyway if no one else has.
Will file a bug right away.
Regards
Senthil
blog | website
Ah, you found the bug on it, Senthil :P My searching skills are apparently diminishing.
Internal issue number for this is DEVXML-328
:: Morten
If someone is going to correct the .xml, they can fix this too
which gives "ADC_ADC_vect" which doesn't correspond with the data sheet. Same error for tiny20.
Make a bugzilla entry on it, so that we are able to track it....
:: Morten
Pages
