ATMEGA 168 - PWM not working?
10 posts / 0 new
I've gone through the data sheet and a few tutorials/example and I can't figure out why this is not working. can anyone help?
I have an led connected to PD6 / Pin12. I'd like to change the brightness. This should make the led go from off to full brightness and then repeat right?
The LED on PINB2 does work.
#define F_CPU 16000000UL
#include
#include
	DDRB |= (1 << PINB1) | (1 << PINB2);	// Set PB1 & PB2 as outputs
	TCCR0A |= (1 << COM0A1) | (1 << COM0A0); // Set OCR0A on TOP, Clear on BOTTOM
	DDRD |= (1 << PIND6);	// Set PD6 as output
	TCCR0A |= (1 << WGM00);
	TCCR0B |= (1 << WGM02) | (1<< CS00);	// set timer 0 for PWM, Phase correct, no prescaling
		for(uint8_t i; i <= 255; i++){
			OCR0A = i;
			_delay_ms(100);
		PORTB ^=  (1 << PINB2); // flash LED to make sure chip is working and code was uploaded
		_delay_ms(1000);
      if (i = 255) i = 0;
Make that
      if (i == 255) i = 0;
to start with.
[EDIT]Oh!, and
   for(uint8_t i; i = 0; i++){
should probably be
   for(uint8_t i; i == 0; i++){
Also, you do not initialize i, and since it is an automatic variable it will take whatever value is at that memory location when you get to the loop.
Your loop seems a bit strange, if you ask me. If you actually had
      OCR0A = i;
      _delay_ms(100);
then, you'd fall out as soon as i was not zero.
If you simply want to go from 0 to 255 then just
for (int i = 0; i < 255; i++)
   // ...whatever...
Newcomer to C, perhaps?
yes new to C but found and fixed the above. I'll post the update code to my first post to keep the thread clean.
Edit: now the PWM led it lit, the brightness does not vary, and the led on PB2 is not working.
Well, we can only imagine what the code actually looks like now...
I've update the code in my first post to reflect the changes.
That is because you now have constructed another for-loop that you can not exit from.
Read my post again. Observe the details. If you don't actually read what I post then I will stop.
Hint: When will an uint8_t not be <= 255?
Sorry i missed that, but wouldn't i = 256 at one point, exiting the loop? why does i < 255 work but not i <= 255?
my blinky led works again, but PWM does not
updated code:
#include
#include
#include
		for(uint8_t i; i < 255; i++){
			OCR0A = i;
			_delay_ms(100);
		_delay_ms(1000);
Edit: wrong code
No. You have i as an uint8_t. Value range for an unsigned eight-bit variable is 0..255 .
Good. Now you are at least not trapped inside an eternal for-loop
Now make sure the loop actually works (i.e. you are not falling out directly). How?, you ask. Answer: Don't bother with the PWM yet. Just blink your LED on PB2, just as you do outside the loop. But make the delay somewhat longer than 100 ms, which might be a tad too fast for you to perceive as blinking. 200 ms, perhaps, so that you can see thte difference between that and the 1 second delay after your for-loop.
When you are sure your loop works as you want, then you focus on the PWM mode of the timer. All fault seeking should ideally be done in small steps, varying and solving one thing at a time. As you're a beginner juggler, it makes no sense to start with more than one ball. :D
Double check every bit you set against the data sheet. Double-check that you are using the mode you intend, and that that mode does what you want.
Also:Double-check that you have the LED connected correctly.
Don't do that. It will make future readers of this thread very confused.
hahaha I figured it out XD. if OCRnx is set as TOP (PWM mode 5) then you loose that PWM channel, that's why it wasn't working.
I set the timer to use mode 1 (top is 0xFF) and it works now.
why would you want to set
I figured it out
Also, you still have not addressed giving your loop counter(s) an initial value. Perhaps no problem THIS time...
