Timestamp problem
4 posts / 0 new
I know that a bit of long code, but could you told me if the way I work
to calculate the TimeStamp is good?. The OneWire code work
Sylvain Bissonnette
void OneWireSetTime(TimeStruct *Time)
    ulong TimeStamp;
    ushort TimeBuffer[4];
    TimeStamp = Time->Hour24;
    TimeStamp *= 3600UL;
    TimeStamp += (Time->Minute * 60UL);
    TimeStamp += Time->Second;
    TimeBuffer[0] = (TimeStamp & 0x000000ff) >> 0;
    TimeBuffer[1] = (TimeStamp & 0x0000ff00) >> 8;
    TimeBuffer[2] = (TimeStamp & 0x00ff0000) >> 16;
    TimeBuffer[3] = (TimeStamp & 0xff000000) >> 24;
    OneWireReset(ONEWIRE_PIN_DEVICE);
    OneWireWriteByte((ONEWIRE_PIN_DEVICE),0xcc); // Skip ROM
    OneWireWriteByte((ONEWIRE_PIN_DEVICE),0x99); // Write command
    OneWireWriteByte((ONEWIRE_PIN_DEVICE),0xac); // Write 32k768 on
    OneWireWriteByte((ONEWIRE_PIN_DEVICE),TimeBuffer[0]);
    OneWireWriteByte((ONEWIRE_PIN_DEVICE),TimeBuffer[1]);
    OneWireWriteByte((ONEWIRE_PIN_DEVICE),TimeBuffer[2]);
    OneWireWriteByte((ONEWIRE_PIN_DEVICE),TimeBuffer[3]);
Name:           void OneWireGetTime(void)
Description:
Input:          none
Output:         none
Misc:
void OneWireGetTime(TimeStruct *Time)
    ulong TimeStamp = 0;
    ushort i;
    OneWireWriteByte(ONEWIRE_PIN_DEVICE,0xcc);  // Skip ROM
    OneWireWriteByte(ONEWIRE_PIN_DEVICE,0x66);  // Read Time
    OneWireReadByte(ONEWIRE_PIN_DEVICE);        // Controle bytes
    for (i=0;i<4;i++) TimeBuffer[i] = OneWireReadByte(ONEWIRE_PIN_DEVICE);// Read all time bytes
    TimeStamp =  TimeBuffer[3];
    TimeStamp =  TimeStamp << 8;
    TimeStamp += TimeBuffer[2];
    TimeStamp += TimeBuffer[1];
    TimeStamp += TimeBuffer[0];
    Time->Hour24   = (TimeStamp % 86400UL) / 3600UL;
    Time->Minute = (TimeStamp % 3600UL)  / 60UL;
    Time->Second = (TimeStamp % 60UL);
    if (Time->Hour24 >= 12) Time->Hour = Time->Hour24 - 12;
    else Time->Hour = Time->Hour24;
Yours truly,
Sylvain Bissonnette
www.microsyl.com
Please use code tags when posting code.
Surely that depends what format you need it in? Is it "Unixtime" you are trying to create?
I don`t need any special format, the RTC is a simple 1 second adder in a 32 bit register, I need to save my time in the RTC and be able to get it back, so the format is not important
Yours truly,
Sylvain Bissonnette
www.microsyl.com
