Encoding input from 8-position switch to use 3 pins
20 posts / 0 new
I want to use an ordinary 8-position rotary switch to select one of eight modes in the AVR. Instead of using an entire port I'm thinking I can use an external logic IC to encode 8 to 3 so it'll only use 3 pins on the AVR. The part I identified to do this would be a 74LS148 or 74LS348. However these seem to be antiquated parts and are relatively expensive. I have no reason to think this wouldn't work but is there an easier way to do this?
Use a quadrature encoder? They come with different pulses per rev and some have detents and some dont. Some have a push switch. 3 inputs: channl a, channel b, and the switch.
Look for a 74HC148. You should be able to find them for less than 50 cents US.
In consideration of others, please RTFM!
The industrial design and function calls for a switch w/ fixed positions as opposed to an endless encoder. I would use an absolute encoder but those are ridiculously expensive and I couldn't even source one reliably in the configuration I need.
Look for a 74HC148.
yes I looked hastily on mouser to get an idea of pricing... I see they are cheap.
Use a set of resistors and ADC, then you will need only one input pin.
Steve A.
Use an 8-position switch with BCD (octal?) output?
http://nl.mouser.com/Electromech...
http://www.digikey.com/scripts/d...
thanks. yes I considered but the onboard adc is already used.
That was the initial idea but absolute encoders cost more than the entire product (ok exhagerating but too expensive). Also I have never been able to source one with a standard 6mm d-shaft (can't afford to add another knob part# to the BOM just for a stupid encoder). Thanks for the input.
I don't know of any AVR with only one ADC!
which AVR do you use?
You mean more than one ADC input. Most have only one actual ADC.
Steve A.
A 3 deck grayhill 8 position rotary switch will work.
ATMega2560 I'm using all 16 channels.
Wow.
Have you thought about charlieplexing?
JJ
The pic attached is basically what I'm proposing. Using a rotary switch and logic saves (5) GPIO and is cheaper than using an absolute encoder (incremental encoder is not an option).
codemode wrote:
The pic attached...
Ah. SP8T switch would make charlieplexing difficult...
Can you substitute a 3P8T rotary switch?
JJ
possibly as long I can source one that's not significantly more than the SP8T
How about a tiny24? All inputs on PORTA, output on PORTB. It can even do your debounce.
Edit: Actually, looking at Digikey, the tiny44 is cheaper.
Steve A.
I must be going senile. Twelve diodes are cheaper than a 3P8T switch. Please excuse the hand-drawn schematic (attached). Any (i.e. the cheapest) diodes will do. Don't forget to enable internal pullups.
This is easier than charlieplexing, which would require a polling routine. Charlieplexing is handy for larger arrays of switches, where the schematic below would grow to include unmanageable numbers of diodes, or where more than one switch can be closed at the same time (although ghosting is a problem for more than 2).
Edit: Not on the schematic, but the common pin on your SP8T switch goes to ground.
JJ
Lorlin make a binary encoded rotary switch which should be price competitive with the standard 8 pole item. Pcb mount and standard shaft.
http://www.newark.com/lorlin/bck...
They have em at skycraft for a buck
