Would you file a GCC bug report?
I cannot say if there will be a working solution for 4.7
You can speed up matters by working out small test case that still reproduces the issue and by following the bug reporting policies.
Georg-Johann Lay has already done it :-) I just added another complaint http://gcc.gnu.org/bugzilla/show_bug.cgi?id=56219
I've tested avr-gcc-4.8.0 20130306 (experimental) and i've got next results: gcc version 4.7.2 4.8.0 mega162proj 14464 14652 + 1.3% of flash usage mega1281proj 71198 71432 + 0.32% of flash usage
Do you plan to make release of 4.7.3 and 4.8.0?
That is:
http://gcc.gnu.org/bugzilla/show...
It's a pity. :(
TopYou can speed up matters by working out small test case that still reproduces the issue and by following the bug reporting policies.
TopGeorg-Johann Lay has already done it :-)
TopI've tested avr-gcc-4.8.0 20130306 (experimental)
TopPages
