How useful is static analysis based stack usage?
10 posts / 0 new
Another one of those "would this be useful" questions :)
I whipped up a quick gcc plugin last night that basically prints
main : 2 : 2
  baz : 4 : 6
  bar : 42 : 44
    barinner : 4 : 48
  foo : 12 : 14
    fooinner : 3 : 17
(read as function name : function stack usage : total stack usage on code path).
for a program with two files, like this
a.c
struct test { int x; int y; };
extern int baz(int);
volatile int z;
void barinner(struct test* tests)
    tests[1].x = tests[1].y;
    z = 4;
void bar()
    struct test tests[10];
    barinner(tests);
    z = 3;
void fooinner(char c) { }
void foo() { char x[10]; fooinner(x[0]); z = 2; }
int main()
    foo();
    bar();
    baz(100);
    return 0;
b.c
int baz(int x) { return x + 1; }
Stack usage for a function is calculated during prologue generation - I just combine that with callgraph information to find out stack usage along function call paths. When used with -flto, you get this information for the whole program, rather than just the translation unit.
This of course, will not be able to look into pre-compiled code (avr-libc, libgcc etc..), or handle recursion.
Do you guys think this would be useful?
Regards
Senthil
blog | website
Definitely!
(I have my own utility for this. But I would certainly welcome something that comes standard with the toolchain.)
Very useful.
How about explicit calls to alloca()?
Yeah, those don't get accounted either.
Also, the function call overhead (return address on stack) is not accounted right now, as linker relaxation can later change calls to jumps. Perhaps I should take a pessimistic approach and show worst case stack usage?
Regards
Senthil
blog | website
gcc has plugins?
gcc has plugins?
That's apparently how LTO works. I think the plugin mechanism was something added in binutils 2.23.
http://gcc.gnu.org/wiki/whopr/dr...
Yes, gcc has had plugins atleast since 4.6.2, and probably before that. See http://gcc.gnu.org/onlinedocs/gc... .
I've put up the source code for my plugin at https://github.com/saaadhu/stack... - not a lot of code really.
Cliff, LTO is done by gcc and linker plugins are only needed if object files inside archives need to be available for LTO. Otherwise, the entire process is managed within the compiler - no binutils support is needed. See http://gcc.gnu.org/wiki/LinkTime... .
Regards
Senthil
blog | website
I'm not familiar with the mechanism(s) you are using for gathering the information. I'd assume automatics are taken into account, and register save?
Anyway, besides recursion I'd also have a disclaimer about nested interrupts.
Putting nested interrupts aside, the posted example doesn't show any ISRs. Practically, one would need to add the largest ISR stack hit to the deepest value from the static analysis, right?
Yes, whatever the compiler figures it needs space for during prologue generation. It just reads a value that is set by the actual compiler code that does prologue generation.
Agreed. I suppose it is possible to figure out worst case usage (assume every possible interrupt could get interrupted at the deepest point), but I don't know if it would be useful.
Yes, ISRs would show up as "root" nodes in the callgraph, just like main, and will show stack usage along with that ISR's function call path. Like you said, adding max ISR stack usage, with max non-ISR stack usage should work.
Code
void foo()
    char x[20];
void __attribute__((signal)) __vector_2()
    foo();
int main()
    return 0;
Stack usage
baz : 4 : 4
main : 2 : 2
  foo : 22 : 24
__vector_2 : 17 : 17
  foo : 22 : 39
Regards
Senthil
blog | website
