Stringification
4 posts / 0 new
Hi All,
wondering if it is possible to place a defined value into a constant string
eg: PSTR ( "sum of the numbers is 30" );
but i want to use the VALUE_SUM define from below
instead of manually typing "30"
#define VALUE1 (10)
#define VALUE2 (20)
#define VALUE_SUM (VALUE1 + VALUE2)
thanks,
But the values are not strings, they are integers. To make them strings you need something like itoa or sprintf, but those aren't available to the preprocessor.
Steve A.
I used this based on samples I found
PSTR ( "sum of the numbers is " XSTR(VALUE_SUM) );
// Stringification
#define XSTR(s) STR(s)
#define STR(s) #s
#define foo 4
STR (foo)
==> "foo"
XSTR (foo)
==> XSTR (4)
==> STR (4)
==> "4"
still need to test it
Stringification does not do what you are expecting...
#define VALUE1 10
#define VALUE2 20
#define VALUE_SUM VALUE1 + VALUE2
#define STR(s)	 #s
const char * sum_string = XSTR(VALUE_SUM);
results in
const char * sum_string = "10 + 20";
see http://gcc.gnu.org/onlinedocs/cpp/Stringification.html
