RTC time of day code available?
6 posts / 0 new
I am using a Xmega processor with the internal RTC that keeps track of time in a 32 bit register. I need to convert that time in a calender format of time and date.
Is there some code available to do that?
Thank You.
Charles :idea:
How do you set the initial time? How do you display it?
What do you mean by "internal RTC"? Do you use an external 32KHz crystal or the internal RC oscillator? If you use the internal RC, you will not be happy with clock accuracy!
Hi Jim,
The Xmega 128D3 has a built in RTC real time counter which can used an external oscillator. I do use that external oscillator for high accuracy.The time will be set by a keypad and display and also thru a computer connected to the USB port. I am just looking for code available to convert the 32 bits counter to a data/time format.
Charles
Best bet is probably to use "unixtime" then you can use POSIX time.h library code to convert this into years/months/days/hours/minutes/seconds since 12:00:00 1-1-1970.
Using unixtime has a number of advantages. For example to calculate the time between two dates/times is just uint32_t - uint32_t. Similarly to do alarms is just if(uint32_t == uint32_t).
Thank You clawson, I will check it out
Counting and displaying the time is far easier than getting an oscillator accurate enough to tell time. Best off to buy one.
In my humble opinion, I'm always right.
