I have a DPDT relay which has a set / reset coil. You pulse in one direction for set and the other for reset and there is no "holding current" after the relay switched over.
I want to drive this type of relay using an AVR and a few transistors but I am wondering how it is done due to the bi-directional nature of the current needed to use the relay.
If someone has some references (could not find something good on Google) it would be much appreciated.
