Trying to understand register assignments
8 posts / 0 new
Looking at a particular code for ATmega328P, I see the following assignment
EIMSK |= (1<<INT0);
The Atmega328p specification clearly says - "Bit 7..2 "“ Res: Reserved Bits"
Is the above not a violation of reserved bits which are supposed to be set to 0?
Below is what I have understood from some preliminary investigation...
I had a look at the header file of ATmega328p and some search revealed the following info
#define EIMSK =_SFR_IO8(0x1D)
#define INT0 0
#define _SFR_IO8(io_addr) ((io_addr) + __SFR_OFFSET)
and
# if __AVR_ARCH__ >= 100
# define __SFR_OFFSET 0x00
# else
# define __SFR_OFFSET 0x20
# endif
so let's assume that EIMSK is essentially 0x2D. So in the original assignment i.e. EIMSK |= (1<<INT0), doesn't 0x2D get written to EIMSK(which itself is also 0x2E - location in address space)? And if this is the case, then it's a clear violation of the reserved bits as mentioned in the specification document. I see that such assignments are very common so most likely I am missing something obvious.
Please help me understand this.
Thanks and regards,
Sandeep K Chaudhary,
University of Waterloo, Canada.
Why would you think that? It sets one bit (INT0) to 1 and leaves all other bits the same. Even if it was "=" instead of "|=", it would set INT0 to 1 and all others to 0.
No, 0x2D is the address of EIMSK, not the value being written.
The "=" does not belong there (and I presume is something that you added).
Steve A.
Ok, thanks. I got confused because if EIMSK were a variable instead of a '#define', then it would have had the value '0x2D' after the mentioned assignment.
Thanks again, Steve !
Thanks and regards,
EIMSK is at address 0x2D.
First, (1<<INT0) ==> (1<<0) ==> 1
So, EIMSK |= (1<<INT0) means: retrieve the value at address 0x2D and OR it with 1
Ie set the lowest bit to a one (the other bits are left unchanged).
Dr. David Harris OpenLCB Development Team openlcb.org
Yeah, ok. Thanks !
I am just wondering what value at address 0x2D we can expect in such cases? I mean, the code I am referring to has the assignment EIMSK |= (1<<INT0); in main and there is no access to EIMSK before this. What default value we can expect in such cases?
Thanks and regards,
s.chaudhary wrote:
Yeah, ok. Thanks !
The power-up initial value, which is typically listed in the manual right below the definitions of the register's bits. Look at the "Initial Value" line at the ends of various register definitions (
Yeah, got it. Thanks !
Thanks and regards,
And by the way, your concern about writing to reserved bits is unfounded. These are simply read only bits, writing to them will do nothing.
Steve A.
