8755 Programming
2 posts / 0 new
Anyone here, based in the UK, able to program a 8755 for me?
I've got an Intel SDK-85 I want to get going but the 8155 PROM/IO, which contains the monitor, is dead. I plan on replacing it with an 8755 but my universal programmer doesn't seem to do them.
It's been a while since I've played with the SDK-85. I still have one somewhere, complete with manuals. I also have access to a programmer that can burn 8755 chips.
The only problem is that I'm in Canada, not the UK.
