PWM on xmega: What am I missing?
6 posts / 0 new
I've used PWM a lot on the regular megas, but fail to make it work on an xmega. I'm using the ATxmega128A1, running at 30 MHz.
I've read the relevant values (those I think are relevant) directly from the registers, so I'm sure that the values are as listed below:
PORTC_DIR=0x9B; // PC7, PC4, PC3, PC1 and PC0 set as outputs
PR_PRPC=0x0C; // SPI and HIRES disabled on port C
TCC1_CTRLB=0x13; // Single slope PWM; CCA compare output enabled
TCC1_CTRLC=0;
TCC1_CTRLD=0; // All event stuff off
TCC1_CTRLE=0; // Byte mode off
TCC1_PER=0x0BB7; // Period register set to 2999
TCC1_CCA=0x001F; // Compare register set to 31
TCC1_CTRLA=0x01; // Timer enabled, no prescaling
I expected to get a 10 kHz signal on PC4, with a pulse width of a little more than 1 µs. Instead, I get a constant low. I've studied the Xmega A manual and several posts here, including this one:
https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=103575&highlight=xmega+pwm
So far, no result. Am I missing something obvious?
ErikT
You're absolutely right. This member is stupid. Please help.
I should add, that PC4 works nicely as an output when I control it directly, so it is not a hardware error.
Have a nice weekend!
ErikT
Here are a couple snippets of one of my pwm timer setups:
    PORTF.DIRSET   = 0xff;                 // setup pout, relay outputs
    PORTF.OUTSET   = 0x0f;
void setuptimerf0 (void)                   // portf timer0 PWM outputs
    TCF0.PER      = 4220;                  //
    TCF0.CCA      = 4000;                  //
    TCF0.CCB      = 3000;                  // compareB 15ms
    TCF0.CCC      = 1000;                  // compareC  5ma
    TCF0.CCD      = 2000;                  // compareD 25%
    TCF0.CTRLA    =  0x01;                 // Work from CPUCLK/1 11.0592mhz
    TCF0.CTRLB    =  0xf3;                 // enable compare A,B,C,D for single slope pwm
//  TCF0.INTCTRLA =  0x01;                 // Enable overflow interrupt
Tom Pappano
Tulsa, Oklahoma
I'm an Xmega newbie so examined this thread with interest.
I traced down the original code and Tom's code, and understand the register settings.
Then I noticed
Aha--check the errata list for this beastie. And indeed
8. Setting HIRES PR bit makes PWM output unavailable
Setting the HIRES Power Reduction (PR) bit for PORTx will make any Frequency or PWM output for the corresponding Timer/Counters (TCx0 and TCx1) unavailable on the pin even if the Hi-Res is not used.
Problem fix/Workaround
Do not write the HIRES PR bit on PORTx when frequency or PWM output from TCx0/1 is used.
Hi Theusch,
Thanks a lot for the work you've put into it! Actually, I did read the whole errata list before the chip was even selected for the project - and then I've obviously forgotten about that one. :oops:
And, dammit, my daughter is ill today, so I can't even get to work to try it!
Thanks again! :)
3 days ago i was search for timer/pwm with xmega and i bookmark this link
- EVAL-04-MOTOR Xmega Development Board
http://www.bostonandroid.com/man...
- Aplication note a Code
http://www.atmel.com/devices/atx...
- ASF
http://asf.atmel.com/docs/3.5.1/...
