Well I knew it was going to be a bad idea upgrading AS6. :evil:
I downloaded the 400+ MB upgrade, installed it, and now I have BOTH (I think and HOPE) AS6 and AS6.1.
Opened the project and it needs to be upgrade for AS6.1, fair enough, I allowed to make a back up but I don't know where the backed files are. Not to worry.
Rebuild the project and start debugging with JTAG Mk3 which needs upgrading, OK.
The code is uploaded and it starts to run, which is NOT what I wanted before I hit F5. Trying to click on Break and it doesn't work, code still runs, the only way to stop it is to stop debugging.
The project configuration (project properties) is no longer there for ASM project but now I'm not even sure it was there with AS6, it is there for C projects, don't know how I set the project up to start off with.
Codevision is no longer in AS6.1, still there is AS6.
AS6 seems to still work, so I hope I can do some work today.
