So in AS4 you could minimize the programmer window and use the AVRISP to download your built code with a single button on the toolbar. I haven't been able to find this feature in AS6. After building I have to select Tools/Device Programming, click the Apply button, select Memories, finally click the program button. Then I can't edit my code until I close the programming window requiring me to go through the whole process again. It's really a pain when you're making small changes or tweaking values. Please tell me I'm just not seeing it and there is a way to download code without going through all that rigamorole.
What happened to one button downloading?
It's [/Debug/Start Without Debugging]
If it doesn't work for you, check the settings in the the Tool tab in your project's properties.
Level: Raving Lunatic
Posts: 6635 View posts
I have not found it either.
From what I recal is that it has disappeared.
what you can do is use the "start without debugging" button
in my set-up it is left of the solution configuration selector(default "debug"). It will build the project and if a programmer is selected it will program the device.
I get it now. I didn't realize that you still need an external JTAG. Since you can program with just the board it seems like you should be able to debug also.
Level: Moderator
Posts: 104935 View posts
You don't. Start without debugging will do ISP/PDI/TPI/dW just as well as JTAG.
