after enabling interrupts, not reaching main's while(1) {...
5 posts / 0 new
Hi All,
i have a strange thing happening, and can't understand whats the reason.
the following code snippet:
void main_init(void)
    irq_initialize_vectors();
    // Initialize the sleep manager
    sleepmgr_init();
    sysclk_init();
    board_init();
    battery_init();
    periodic_init((periodic_event_callback_t)periodic_cb);
    eeprom_init();
    app_init();
    /* init usb i/f and register handlers */
    usb_if_usb_init((usb_rx_callback_t)usb_incoming_data_handler,
                    (usb_event_callback_t)usb_attach_handler,
                    (usb_event_callback_t)usb_detach_handler);
void main_start(void)
    battery_start();
    udc_start();
    if (!udc_include_vbus_monitoring()) {
        usb_if_vbus_action(true);
    cpu_irq_enable();
/*! \brief Main function. Execution starts here.
    main_init();
    main_start();
    // The main loop manages only the power mode
    // because the USB management is done by interrupt
    while (1);
        sleepmgr_enter_sleep();
        if (local_app_conf_changed)
            local_app_conf_changed = false;
$ Fixed code tags - JS $
will never execute the while(1) {...}
(i see that the code is never executed. setting a breakpoint there and running, is disabled via the avr-studio - saying that setting bp at runtime is not allowed, even though the bp is set not at runtime.
setting a bp at main_start() will work).
any idea?
thanks in advance!
Mickey
You probably enable an interrupt without providing an ISR() for it. Try the BADISR mechanism.
mickey_at wrote:
    while (1);
Remove the semicolon from that line, and you may see more action.
Sid
Life... is a state of mind
I'm betting Chauncy found it. Got me once on a IF statement.
Hi, Thank you all for your replies!
you were right! i miss-noticed the semi-colon.
Thanks again, you are great!
